Wipers stay up when turned off
Old Jan 25, 2004 | 12:50 PM
Feydakin's Avatar
Feydakin
Default Wipers stay up when turned off
Ok, strange one here..
When you turn off the wipers they move straight up.. When you set them to delay, they pause in the proper down position.. My wife says this happened a few days ago, but 'forgot' to tell me until I drove it today.. Imgine that..
Anyway, any ideas??
Old Jan 25, 2004 | 04:48 PM
dpd's Avatar
dpd
Default Re: Wipers stay up when turned off (Feydakin)
does pulse,low,high all work as normal?also the washers?ould be a couple of possibilities depending on what works and what doesn't.did this happen after rain/snow melt?
Old Jan 25, 2004 | 04:56 PM
Feydakin's Avatar
Feydakin
Default Re: Wipers stay up when turned off (dpd)
As far as I can tell, everything works like it should.. Except, when you turn them off.. They move down, and just before they slip below the hood line, they pop back up to a nearly perfect verticle position..
And yes, this happened in cold weather/snow.. It sits in a parking garage in the day, my garage at night, road hazards back and forth :)
Old Jan 25, 2004 | 05:03 PM
dpd's Avatar
dpd
ok,you said your wife noticed this.ask your wife if she turned on the wipers and if they stuck to the windshield for a second.if so,the plastic park arm in the wiper motor cover circuit board probably broke for the park switch.
Old Jan 25, 2004 | 05:11 PM
Feydakin's Avatar
Feydakin
She's shaking her head no :) And says, "I don't think so".. So, if this is what broke, where do I need to dig to get a look at it??
Old Jan 25, 2004 | 05:41 PM
dpd's Avatar
dpd
park is controlled by the park switch inside the wiper motor,which tells the wiper control module to park the wipers.the only way to check this is to take the wiper motor off the car and take it apart to see if the pin/park switch broke.to make sure it isn't the stalk switch[i doubt it,but they have been known to go bad].if you unplug the wiper motor,you should see 5 wires.1 black[ground],yellow,green,purple,and gray[don't swear me to the colors,but i think i'm close].anyway with the key on and the stalk switch off,you should only have power on the yellow wire.with key off,you should have no power on any wire.if this is ok,the switch is fine.more than likely you are pulling the wiper motor/control module off.
Old Jan 26, 2004 | 09:47 PM
Feydakin's Avatar
Feydakin
Ok, wife drove it today and half way to work she had to use the wipers.. Used them, turned them off, they went down and stayed down..
Came home from work, used them, now they stay up again.. Very strange.. I told her to call the dealer and take it in.. The car only has 5k miles on it..
Old Jan 26, 2004 | 09:58 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
________________________________________ ________________________
Glad to hear that you are under warranty........after all is said and done......let us know what the cause of the problem was.
Old Jan 26, 2004 | 10:33 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Default Re: Wipers stay up when turned off (vette#one)
:lurk: Interesting problem. Let us know what they find. :thumbs: :seeya
Old Feb 6, 2004 | 06:36 PM
Feydakin's Avatar
Feydakin
Ok, just got the car back from the shop.. It was a broken crank arm.. Not sure why it would worl occasionally, but they fixed it under warranty in a couple of hours.. So all is good..
well, except for the fact they were shocked that we were actually driving it in this weather :)
Thanks to everyone that offered suggestions and help..
To Wipers stay up when turned off
