tested car, pulled all fuses, STILL have current drain
Old Jan 25, 2004 | 06:05 PM
lucaslawfirm's Avatar
lucaslawfirm
Default tested car, pulled all fuses, STILL have current drain
I hooked up the multitester between the positive cable and the post, set it to 10, it pegged, set it to 50 and it stayed at "5", I pulled each underhood fuse individually, no change, I got in, shut the door and pulled each fuse and breaker in the footwell, no change. Anyone have any ideas? Could it be the battery cable or the starter leaking to ground? The only electrical oddity I've ever noticed on this car is the security light sometimes stays on when driving. When it won't start it takes a while after I hook up the jumper cables before it builds up enough juice to start, but you can run it for a minute or two and shut it down, it'll fire right back up. There was a minor amount of crud on the terminals, under them, the battery shelf looks brand new, and the old battery was a replacement. I really thought the test would show something.
Jay :banghead: :banghead: :banghead:
Old Jan 25, 2004 | 06:15 PM
Alex D's Avatar
Alex D
Default Re: tested car, pulled all fuses, STILL have current drain (lucaslawfirm)
DO you have a CD changer?? I once had a 12 disc changer that went bad and came on intermittently and draine dthe batt over two to four days. If you have one, onhook and see if it makes a diff.
Old Jan 25, 2004 | 06:19 PM
lucaslawfirm
Yes, the factory one, I'll try that, I seem to recall the car did this once before, anyone else have any ideas?
Jay :leaving:
Old Jan 25, 2004 | 07:06 PM
Alex D's Avatar
Alex D
They are hooked into the serial data line going thru the vehicle and everytime my player would wake up and do stuff, it would wake the entire data line and all components up. Had the car towed to the dealer three times. They exchanged everything until I cought the palyer doing its thing one night walking into the garage. it would just start initializing on a whim and that woke the entire network up which drained the batt in about three to four days. Got a new CD player form GM afterwards. :yesnod:
Old Jan 26, 2004 | 09:26 AM
Fast one's Avatar
Fast one
Default Re: tested car, pulled all fuses, STILL have current drain (Alex D)
After the battery is disconnected, disconnect the alternator and tape the wire end so it can't short to ground and then check the current draw again. A bad alternator can draw current all the time.
Old Jan 26, 2004 | 10:20 AM
lucaslawfirm
I'll try the alternator this afternoon. CD player wasn't the issue.
Thanks,
Jay :banghead:
Old Jan 26, 2004 | 11:43 AM
WestCoastCorvette's Avatar
WestCoastCorvette
Supporting Vendor
Unplug the seat tracks also.
:yesnod:
Old Jan 26, 2004 | 05:45 PM
Mitch Alsup's Avatar
Mitch Alsup
Any aftermarket wires hanging off the positive terminal? Alarm, Stereo, Amplifier,...?
Old Jan 26, 2004 | 06:33 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Re: tested car, pulled all fuses, STILL have current drain (Fast one)
Your security light stays on????? It not suppose to do that... you need to fix that first...
Old Jan 26, 2004 | 07:42 PM
dpd's Avatar
dpd
the proper way to check for a current drain is to hook your multimeter to the NEG side between the cable and the post.have your meter on the amp scale[red lead in the 10a fused scale of the meter].after you let everything time out,you should see between 20-30ma[.020-.030].i'm assuming your meter is showing you 5 amps.if it's showing you 5 amps,you have a heavy load[be it the alternator/starter].with that kind of draw,whatever is pulling the battery down will be hot and the battery should be dead overnight.i'm also assuming you're using a digital multimeter[fluke,etc.].
Old Jan 27, 2004 | 12:37 PM
lucaslawfirm
Used an analog gauge, but I guess it's got to be the alternator or starter, will check further. There are no aftermarket electronics in the car, what's the deal with the security light, anyojne had that problem (intermittent on while driving)?
Thanks,
Jay
Old Jan 27, 2004 | 05:02 PM
dpd's Avatar
dpd
if you're using a analog meter,you are chasing your tail[not enough impendance].you have to get a digital meter to check it right.
Old Jan 27, 2004 | 08:13 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: tested car, pulled all fuses, STILL have current drain (Evil-Twin)
:iagree:
Maybe one of the door switches is malfunctioning, I know this is a common problem on the C3 and I'm not familiar with how the switch is supposed to operate on the C5 but that may be a good place to look :cheers:
To tested car, pulled all fuses, STILL have current drain
