Speed Bleeders
Old Jan 26, 2004 | 08:51 PM
C5 Hardtop's Avatar
C5 Hardtop
Default Speed Bleeders
I got some speed bleeders. When comparing the speed bleeders to the stock bleeder valve, you can see the speed bleeder is shorter. I know I have the right one as we looked it up in the book and it threads in ok. It just seems to stop screwing when the threads run out. I screwed it in a long ways. I'm worried.
Joel
Old Jan 26, 2004 | 10:10 PM
Richin Chicago's Avatar
Richin Chicago
Default Re: Speed Bleeders (C5 Hardtop)
Joel
If you got the SB1010 which is 1.35" long it should be fine for stock C5 calipers. I have had mine for several years with no problem. Just be sure you didn't get the SB1010S (the "S" is for short) which are only 1.23".
Old Jan 26, 2004 | 10:23 PM
GotXqss's Avatar
GotXqss
Default Re: Speed Bleeders (Richin Chicago)
So who sells this setup.. I emailed speedbleeders about 2 weeks ago and havent got a reply :nonod:
Someone perferabally with some customer sevice and good deal???
Old Jan 26, 2004 | 10:50 PM
MNCrystalRed2011's Avatar
MNCrystalRed2011
Default Re: Speed Bleeders (GotXqss)
I got mine at Mid America Designs (madvet.com) :thumbs:
Old Jan 26, 2004 | 10:56 PM
speedyc5's Avatar
speedyc5
How does a speed bleeder differ from a stock bleeder. I have been thinking about these but not understanding the difference.
:confused: :confused: :confused:
Old Jan 26, 2004 | 11:36 PM
MNCrystalRed2011
Default Re: Speed Bleeders (speedyc5)
There is a little check ball in them that allows you to pump the brake pedal to get the air out, but not let any air back in. I don't have mine installed yet, but know people that do and they work great. Don't need a second person to bleed your brakes.
Old Jan 27, 2004 | 12:59 AM
Richin Chicago
http://www.speedbleeder.com/feature.htm
To Speed Bleeders
