ANYONE PULLED THEIR ENGINE FROM THE TOP?
Old Jan 28, 2004 | 08:34 PM
bamcoc5's Avatar
bamcoc5
Default ANYONE PULLED THEIR ENGINE FROM THE TOP?
I am thinking of pullng my engine and doing a forged short block. The one hurdle is pulling the engine. I have been told normal removal is through the bottom. I don't have a lift so that is out. I have read of a few taking it out the top. I am open to suggestions.
Old Jan 28, 2004 | 08:48 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: ANYONE PULLED THEIR ENGINE FROM THE TOP? (bamcoc5)
Yes, just just pull the tunnel back away from the engine, remove the radiator, and you are a go. You can also leave the AC intact if you want. I would pull the intake and valve covers off for clearance though. We did Tom Garland's C5 on jackstands this way.
I have had my engine pulled from the bottom and it is easier that way b/c it will drop down with the front cradle.
[Modified by C5-VERT, 8:49 PM 1/28/2004]
Old Jan 28, 2004 | 09:22 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
I did mine from the top, and if you lower the front crossmember you don't have to do anything with the torque tube/trans/rear. Just slide the motor forward a little then up. I also left my a/c and front brake lines/ ABS stuff all intact. not bad at all.
Old Jan 28, 2004 | 10:18 PM
bamcoc5's Avatar
bamcoc5
Default Re: ANYONE PULLED THEIR ENGINE FROM THE TOP? (Flyin'Brian)
Thanks thats what I wanted to hear. :hurray:
Old Jan 29, 2004 | 02:44 AM
blu00rdstr's Avatar
blu00rdstr
Ditto that. Pulled mine from the top the same way.
Old Jan 29, 2004 | 09:07 AM
Tree's Avatar
Tree
Default Re: ANYONE PULLED THEIR ENGINE FROM THE TOP? (blu00rdstr)
You don't even have to remove the radiator and fans if you remove all the accessories from the front. Also you don't have to remove the balancer, though it would be slightly easier if you did, and it sounds like you'll be taking it off anyway. It's a bit of a pain, especially in the car. ABS stays in, rack comes out, A/C compresor stays in and hooked up to lines.
To ANYONE PULLED THEIR ENGINE FROM THE TOP?
