removing A4 transmission and differential
Old Jan 29, 2004 | 10:28 AM
98silverC5's Avatar
98silverC5
Default removing A4 transmission and differential
I know you can remove the differential without disconnecting the torque tube from the motor but my question is can you remove an A4 transmission and differential together without unbolting the torque tube? Thanks!
Old Jan 29, 2004 | 02:38 PM
98VETTEC5's Avatar
98VETTEC5
Default Re: removing A4 transmission and differential (98silverC5)
yes you can just lower it all down and slide it out!
Old Jan 29, 2004 | 06:25 PM
98silverC5's Avatar
98silverC5
Default Re: removing A4 transmission and differential (98VETTEC5)
Thanks Kevin....time to begin another winter project! :thumbs:
To removing A4 transmission and differential
