Line lock recomendation
Old Jan 29, 2004 | 09:23 PM
HawkIVette's Avatar
HawkIVette
Default Line lock recomendation
I posted this over in the Drag Racing section, but didn't go over very well.
So I 'll try it over here.......
Did a search and can't come up with much on the subject.
What line locks are you guys using and how was ease of installation?
give me some links and prices. Thanks
Old Jan 29, 2004 | 09:29 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Line lock recomendation (HawkIVette)
I had the TCI unit from Summit Racing and will be going that route again, got all the hardware locally as we have a HUGE fastener warehouse closeby :)
Old Jan 29, 2004 | 10:36 PM
GraveDigger's Avatar
GraveDigger
Don't buy from Cartek. They will take your money and send you the wrong part and never make good on all thier promises, ain't that right Dave. Many months have passed and after stating on this forum infront of everyone they would make it right and still nothing. Great service Dave :cheers: :bs
Old Jan 30, 2004 | 12:34 PM
BadBeagle's Avatar
BadBeagle
Default Re: Line lock recomendation (GraveDigger)
:withstupid:
Old Jan 30, 2004 | 01:41 PM
kromberg's Avatar
kromberg
I am using the $79.95 TCI linelock from http://www.summitracing.com and it very easy to install.
Keith
Old Jan 30, 2004 | 01:49 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
They sent me one wrong fitting to go into the porportiopnal valve. I took off the original fitting and had Earl's Performance parts modify the line to fit, cost $5. I didn't have time to wait on Cartek, because the installation was almost complete when I discovered the problem.
Old Jan 30, 2004 | 02:04 PM
crom's Avatar
crom
Default Re: Line lock recomendation (wallstAL)
Would someone explain to me how the line lock works and where in the breaking system it goes? I already understand that it locks the front tires to allow you to do burnouts but don't know how. Thanks. (Hope I'm not hijacking your thread, if so, I'll edit my post out)
Old Jan 31, 2004 | 05:33 PM
HawkIVette's Avatar
HawkIVette
Default Re: Line lock recomendation (crom)
Thanks guys for the heads up on Cartek. I am still looking for more info, but will check out the summit racing tip. Thanks
Now to crom, I am not all that knowledgeable about line locks either, but here is what I know.
A line lock is kinda like a check valve that, once the brakes are applied and held, you turn on a switch that would hold the fluid from releasing (the front brakes only). After your burn out (remember only front brakes are locked), you release the switch, therefore allowing your wheels to roll.
Old Feb 1, 2004 | 02:43 PM
badddrx7's Avatar
badddrx7
I take it that you mean the TCI 861700 kit. What fittings did you have to buy and exactly where did you cut and mount the Line Loc ?
How did it affect ABS ?
Tom
Old Feb 1, 2004 | 03:15 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Line lock recomendation (badddrx7)
:yesnod:
I bought ISO fittings locally from a parts supply house and still have the old rig from my convertible, I plan on going down there and get a duplicate set for my new install and also to document the exact fittings, so others can easily obtain 'em :)
The line from the proportioning valve to the ABS block, there are two and you need to "splice" the line-loc between the one for the front brakes.
None at all, just make sure to bleed correctly and I suggest a "power bleeder" from RedShift's site :cheers:
Old Feb 1, 2004 | 04:04 PM
gojo's Avatar
gojo
There are lots of posts on the line lock. Search archived and don't put in a
forum choice.
I believe there are different fittings for different years. I have an 03' and had to have the line from the master to the line lock custom made. The fitting was a different size from earlier years.
Old Feb 1, 2004 | 04:36 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Default Re: Line lock recomendation (Mean Green)
TCI ROLL STOP from Summit racing :D
Bob
Old Feb 1, 2004 | 07:37 PM
badddrx7's Avatar
badddrx7
Default Re: Line lock recomendation (16Again)
I have an 2002 z06, does someone know the exact size of the line that comes from the Master cylinder to the ABS unit by the altenator ?
Tom
Old Feb 1, 2004 | 09:12 PM
WHY2KRAG's Avatar
WHY2KRAG
Hurst Roll Control :D :thumbs:
To Line lock recomendation
