Breaks Question
Old Jan 30, 2004 | 08:01 PM
scool93535's Avatar
scool93535
Default Breaks Question
The other night I got on the breaks very hard, into the anti-locks, at high speed due to a stalled car in a dark runout at the track.
Afterwards I nursed it home using the 6spd to slow down with very minimal breaking to just bing it to a full stop when neccessary. I thought perhaps I blew a hose to a slave cylinder or the fitting came loose due to the pumping action of the ABS.
I can't find any fluid under the car and, with it running, if I hold the break down hard, it doesn't creep towards the floor like a leaky wheel cylinder.
It feels more like the piston in the master cylinder is not returning when you let off the break? Is that possible? The peddle feels very light for about 3/4 of its travel then it presents a more normal feel.
Ideas??
Thanks,
Steve, WCCC - CC2
[Modified by scool93535, 5:05 PM 1/30/2004]
Old Jan 30, 2004 | 08:56 PM
danielschulzjr's Avatar
danielschulzjr
Default Re: Breaks Question (scool93535)
you may have boiled the fluid, that puts air in the system. Try bleeding the brakes and see if that help.
Old Jan 30, 2004 | 10:59 PM
Kenny94945's Avatar
Kenny94945
One hard stop and you have a brake issue?
Well, look for oil at the calipers. Check the fluid level in the master cylinder reservior.
Could be air if all checks out so go for a bleed.
Perhaps some abs stopping test could be safely done.
Seems strange as these cars can abs stop all day long.
Old Jan 30, 2004 | 11:07 PM
VetteDrmr's Avatar
VetteDrmr
It could also be a stick caliper that is now cocked slightly. That can allow the piston in that caliper to be pushed back by the rotor, and you've got to push it back to the rotor disk before you can start braking.
Easiest thing to do is pull the calipers and clean/grease the slide pins. Then I'd bleed the brakes and see where you are then.
HTH, and have a good one,
Mike
Old Feb 2, 2004 | 11:33 PM
scool93535's Avatar
scool93535
Default Re: Breaks Question (Kenny94945)
Yea you would think they could take a hard stop. Maybe at 95K miles the system is getting tired.;-)
The fluid level in the master seems to be a little lower, maybe an 1/8 of an inch. I like the bleading idea, I'll check it out.
Thanks for the ideas.
:cheers:
To Breaks Question
