TIRE PRESSURE!!!!!
Old Jan 30, 2004 | 10:19 PM
JSMITH1615's Avatar
JSMITH1615
Default TIRE PRESSURE!!!!!
anyone know the best tire pressure???????????? 04, coupe
[Modified by JSMITH1615, 3:21 AM 1/31/2004]
Old Jan 30, 2004 | 10:29 PM
gbecton's Avatar
gbecton
Default Re: TIRE PRESSURE!!!!! (JSMITH1615)
I go with what's recommended by Chevrolet, i.e. 30 PSI for the street. :steering:
Old Jan 30, 2004 | 10:44 PM
ScottZ's Avatar
ScottZ
Depends on how you drive it. If just leisurely cruising, then factory recommendation of 30 psi is just fine. But, if you drive very agressively (and I don't mean running people off the road :p: ) then you may prefer a slightly higher tire pressure (32-34 psi) to give you better cornering abilities.
Old Jan 30, 2004 | 11:01 PM
Kenny94945's Avatar
Kenny94945
30/30 cold is a good starting point.
Just adjust as your tires wear. For example if you are wearing the center of your rear tires more than their edges, let some air out.
FYI I run firstone runflats at 25 rear/ 33 front. That works (wear and feeling wies) for me.
To TIRE PRESSURE!!!!!
