tranny question
Old Jan 31, 2004 | 08:12 PM
Corvettaholic's Avatar
Corvettaholic
Default tranny question
Ok, me and my buddy are having a big disagreement on this. He's a nova guy, and i'm a C4 guy, so neither of us knows C5's that well. I heard somewhere that the transmission is not direclty bolted to engine but instead it sits farther down the drive train somewhere? He says thats crap. So whats the deal on transmissions? where are they? and why? thanks guys! :D
Old Jan 31, 2004 | 08:36 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: tranny question (Corvettaholic)
Transmission is not bolted to the tranney directly, there is a torque tube that connects to the motor. The rear is bolted directly to the tranney
Old Jan 31, 2004 | 08:38 PM
jerrymcb's Avatar
jerrymcb
It is in the rear bolted to the differental. The drive shaft runs
through a torqe tube to the clutch mounted on the engine flywheel.
Old Feb 1, 2004 | 09:21 AM
VetteTech81's Avatar
VetteTech81
Default Re: tranny question (jerrymcb)
Yup, and the drive shaft in the torque tube turns at engine speed.. you rev it to 7grand and it's spining 7grand.. just cool how it works.. Also not only is the trans in the rear but the but like he said the diff is bolted directly to the trans.. it's just cool... I love the C5..
-Rick
Old Feb 1, 2004 | 09:49 AM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: tranny question (VetteTech81)
Also, if you have a manual tranny the flywheel and clutch assy is on the engine. but in the auto tranny car the torque converter is on the front of the tranny in the rear, 'cause it needs tranny fluid :thumbs:
Old Feb 1, 2004 | 10:00 AM
Flyin'Brian
Cruise-In I Veteran
and why?
Oh yah....The C5 has 51/49 front to rear weight distribution, very nicely balenced :yesnod:
Old Feb 2, 2004 | 02:31 AM
Corvettaholic
Default Re: tranny question (Flyin'Brian)
thanks for the info guys, now I can rub my buddy's face in it. And he owes me lunch. It probably wouldn't be feasable to do that to my 85... and I never even thought of the weight distribution before. Really good idea. are the C6's like that too?
Old Feb 2, 2004 | 10:06 PM
Bill Dearborn's Avatar
Bill Dearborn
The C6's are the same. However, they have moved the front and rear wheels further apart and the weight balance from front to rear is now 49/51.
Bill
Old Feb 2, 2004 | 10:38 PM
joemoia's Avatar
joemoia
And the technical term for a rear mounted transmission such as the C5's is "transaxle"
Old Feb 2, 2004 | 11:01 PM
Sack Rat TT's Avatar
Sack Rat TT
Default Re: tranny question (joemoia)
Ferrari and Alpha Romero (sp) and others did this in the 50's and 60's if memory serves me right. Not new but very effective. I think this was the greatest engineering change from the C-4 to C-5.
:smash: :smash:
Old Feb 2, 2004 | 11:45 PM
joemoia's Avatar
joemoia
Default Re: tranny question (Sack Rat TT)
:smash: :smash:
Early 60's Pontiac Tempests also were designed with tranaxles.
Old Feb 2, 2004 | 11:51 PM
gojo's Avatar
gojo
http://mikemercury.home.att.net/342.htm
If he still doesn't believe it show him the pictures in this link.
Old Feb 3, 2004 | 12:05 PM
Corvettaholic
Default Re: tranny question (gojo)
just printed them out, this is PERFECT. I called my buddy last night and told him every C5 guy swears that there IS a transaxle! Still didn't really believe me. Says that he SAW a C5 and he didn't see it. Maybe cause he's blind. But tonight the score will be settled, thanks again guys!
Old Feb 3, 2004 | 07:20 PM
VetteTech81
I'm really not sure If I can agree or not.. I always thought a trans axel was a trans where the differential was part of the trans case.. The 4L60E in your C5 is the same as one from a tahoe or most GM rear wheel drive.. the main differences are the bell housing is specific to corvette.. and the out put shaft is specific.. and there is no tail shaft. the output shaft is directly inside the diff.. so I'm not sure if you can call it a trans axel.. like some chryslers have a standard mounted engine and are front wheel drive.. the trans on those is a trans axel because the diff is part of the case.. atleast I think.. either way who cares there both trans's
-Rick
Old Feb 3, 2004 | 10:19 PM
66ImpalaLT1's Avatar
66ImpalaLT1
I dont consider it a transaxle because the differential and transmission do not share fluid. I've always heard of transaxles in applications where the gears and diff are in the same oil as the transmission.
Show these pictures to your friend:
Assembled - http://www.zerohp.com/photos/clutch/m/P1010001.jpg
Torque tube - http://www.zerohp.com/photos/clutch/...rain%20001.jpg
Transmission - http://www.zerohp.com/photos/clutch/...rain%20002.jpg
Rear end - http://www.zerohp.com/photos/clutch/...rain%20003.jpg
Old Feb 3, 2004 | 10:26 PM
Bone_Stock's Avatar
Bone_Stock
Default Re: tranny question (66ImpalaLT1)
You should have laid down more than a free lunch :lol:
Old Feb 3, 2004 | 11:16 PM
joemoia's Avatar
joemoia
I believe you are correct, a true transaxle has tranny and diff. in one case, my bad.
Old Feb 4, 2004 | 01:16 PM
ersatz928's Avatar
ersatz928
Porsche 924s, 944s, and 928s had the same drivetrain layout.
To tranny question
