Valve Spring question
Old Feb 1, 2004 | 01:34 PM
JayMullen's Avatar
JayMullen
Default Valve Spring question
For those thinking about a "cam only" mod, is it necessary to remove the heads to swap out the valve springs or can they be done with the heads intact?
Thanks for your feedback on this. I'm still on the fence as to Cam only or
heads and cam.
[Modified by JayMullen, 6:35 PM 2/1/2004]
Old Feb 1, 2004 | 01:39 PM
XTrooper's Avatar
XTrooper
Default Re: Valve Spring question (JayMullen)
The valves can very easily be replaced with the heads on the motor.
Old Feb 1, 2004 | 03:21 PM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
Default Re: Valve Spring question (XTrooper)
Hey trooper - I'm thinking you meant valve springs - and not "valves" - right? :thumbs: :lurk:
Old Feb 1, 2004 | 04:54 PM
XTrooper's Avatar
XTrooper
Default Re: Valve Spring question (1stGlance)
HAHAHA :D Yeah, that's valve springs, folks. I'd have to renew my magician's license to pull off that one! ;)
[Modified by XTrooper, 4:55 PM 2/1/2004]
Old Feb 1, 2004 | 05:01 PM
JayMullen's Avatar
JayMullen
Thanks you guys. I appreciate the feedback. Next question, could a reputable tuner install a cam and dyno tune in a day? If not .....how long??
Old Feb 1, 2004 | 05:14 PM
XTrooper's Avatar
XTrooper
Could they? Yes. Would they? That's another question altogether. ;)
To Valve Spring question
