where to put jack stands
Old Feb 1, 2004 | 05:09 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Default where to put jack stands
ok I know where to jack up the car to lift , but where 's the best place to place jack stands at each wheel?
any pictures ?
Old Feb 1, 2004 | 11:19 PM
jl240z's Avatar
jl240z
Default Re: where to put jack stands (phils C5 vette)
You need to place the jackstands under the front and rear cross members. Make sure to span at least two of the ribs of the casting. It is best to place a pad of some sort between the jack stand and the cross member. I use a piece of 3/4 in plywood about 8" square or an 2x8 square. This spans the casting and protects it from the jack stand head. :steering:
Old Feb 2, 2004 | 07:33 AM
lowdowndirty's Avatar
lowdowndirty
Default Re: where to put jack stands (jl240z)
:iagree:
Old Feb 2, 2004 | 03:59 PM
Zen06's Avatar
Zen06
What about the hockey puck under the slots in the sides? I see a lot of people doing this. Which is better? :confused:
Old Feb 3, 2004 | 12:33 AM
LivinTheDream's Avatar
LivinTheDream
Default Re: where to put jack stands (Zen06)
Depends on what you're doing. I first put stands under the crossmembers for best stability. Can be tough if you have to wrench in that area, though--so pucks at the sides would help in those cases. I got fed up and bought a used KwikLift; raising the car now takes 3 minutes, and I can creep underneath. The peace of mind was worth a few hundred bucks.
Old Feb 3, 2004 | 07:06 AM
phils C5 vette
Default Re: where to put jack stands (LivinTheDream)
what's kwik lift ?
Old Feb 3, 2004 | 07:14 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
http://www.kwiklift.com/
Old Feb 3, 2004 | 11:26 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
From a safety point of view.. I use Rhino ramps ( 20 dollars ) drive up on them then jack the back end up spanning the cross member with a 2 X 6.. then I put my puck "IN" the rear slots.. lower the car in the rear, to the Jack stands.. I leave my racing jack in the back... but not under load.. If I need to get the front higher.. which is rarely the case... I use my 3 ton jack in the front at the lower A frame jacking points.. leaving the Rhino ramps in place...
Old Feb 3, 2004 | 12:04 PM
Fast one's Avatar
Fast one
Default Re: where to put jack stands (Evil-Twin)
The frame savers allow you to use any part of the frame sides without denting them.
Old Feb 3, 2004 | 12:52 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
:iagree: Bingo
To where to put jack stands
