Glasspacks???
Old Feb 1, 2004 | 08:53 PM
Ellinaras's Avatar
Ellinaras
Default Glasspacks???
What's up ?
Anybody out there that has tried glasspacks or has heard any C5 with them?
Are they a ridiculous idea??
or could it be OK??? :crazy: :yesnod:
Old Feb 1, 2004 | 09:35 PM
lowdowndirty's Avatar
lowdowndirty
Default Re: Glasspacks??? (Ellinaras)
Are you serious?
Glasspacks are for farm trucks!
Oh yeah, and welcome.
Old Feb 1, 2004 | 09:40 PM
Avanti's Avatar
Avanti
Rediculous? No way! My favorite sounding car of all time was one I owned with a pair of glasspacks, each about 40" long (no H or X-pipe), running a Paxton supercharger and fairly mild cam. I've never been able to duplicate it since.
It was not state of the art nor the best for performance (like it needed more), but did it ever "purrrrrrrr" unlike anything I've ever experienced... I can still hear it... Drat, ya got me started thinking about 'er all over...
If I weren't so fond of the ti's on the C-5 I might have experimented with multi-glasspacks of some sort.
All the best.
Old Feb 1, 2004 | 09:41 PM
User 81424's Avatar
User 81424
You'd have to use the very short ones and most people who are going to that trouble just run open pipes.
Old Feb 1, 2004 | 10:00 PM
Ellinaras's Avatar
Ellinaras
Default Re: Glasspacks??? (CPT Z06)
Completely open pipes is not a bad idea, (I already have cutouts anyway), but in my older cars I had tried all kinds of expensive mufflers but the glasspacks always sounded special...
It should be interesting to know if anybody out there has already tried them :chevy
Old Feb 2, 2004 | 12:27 AM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
I have galsspacks on my Valkyrie motorcycle - and I love the sound of them.
Never thought about putting them on the vert. :lurk:
It might indeed provide an awsome sound! :iagree:
Old Feb 2, 2004 | 11:53 AM
Dr. Dirt's Avatar
Dr. Dirt
Default Re: Glasspacks??? (1stGlance)
If you like the sound and are willing to deal with the loss of performace for that sound then by all means, go glasspack.
Old Feb 2, 2004 | 12:10 PM
vmspionage's Avatar
vmspionage
Default Re: Glasspacks??? (Dr. Dirt)
How are you going to loose performance??? A glasspack is just a straight-through exaust pipe wrapped in fiberglass. Lower restriction will cost you a little bit of low end torque, but you'll pick up more HP up top.
I have a setup I made with two Dynomax 14" "race only" glasspacks welded side by side and fit in the exaust tunnel right after the cats. I welded the old flanges to them and finished it off with a SLP Loudmouth system.
It was loud as hell obviously, but it smoothed the sound out and got rid of that "motorboat" sound if you've ever heard the LM system before. I would have kept them but I replaced the setup with the SLP Xpipe/resonator because I thought it was rattleing but it turns out it was something else. The sound was much louder than the SLP Xpipe/LM combo and I might put them back on one day :)
Old Feb 2, 2004 | 01:24 PM
Fast one's Avatar
Fast one
Default Re: Glasspacks??? (vmspionage)
Aren't Stingers glasspacks?
Old Feb 2, 2004 | 01:32 PM
J-Rod's Avatar
J-Rod
Default Re: Glasspacks??? (Fast one)
Most glasspacks (or Smittys if you are from the old school) actually create some turbulence, and flow less than some of the more modern mufflers. If you want a semi-glass pack muffler you can get a Walker Stainless Steel ultraflow. We use them on Grand Nationals they are similar to a glasspack in design, but they use Stainless Steel instead of fiberglass. The problem would be finding a way to route them. Most glass packs are too long to fit within the confines of a C5. If you want loud, go B&B. Basically an open pipe with a small resonator sitting off to one side.
Old Feb 2, 2004 | 01:59 PM
C5XTASY's Avatar
C5XTASY
Default Re: Glasspacks??? (J-Rod)
GHLs use a stainless steel wool filling, rather than fiberglass, like the old glasspacks. We used to dump some oil down the old glasspacks to help burn out the fiberglass faster. Guess that won't work on my GHLs. :D
Ed
Old Feb 2, 2004 | 04:56 PM
Al '92's Avatar
Al '92
Glasspacks were on my '75 when I bought it. Sounded good so I never bothered replacing them. :D
If you're looking for a cheap, free flowing exhaust, get some straight pipes made at a local shop.
Old Feb 2, 2004 | 05:02 PM
Coolaid's Avatar
Coolaid
Spend the money and buy a cam
Old Feb 2, 2004 | 09:18 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: Glasspacks??? (Avanti)
The exhaust that is currently on my car is basically glasspacks. I run straight exhaust on the car until the tips. The tips are glasspacks. I think the car sounds awesome with those tips and my cam. Kaley
Old Feb 2, 2004 | 09:22 PM
99CorvetteFRC's Avatar
99CorvetteFRC
I have glasspacks on my 99 FRC
Strait pipe is way to loud the glasspacks mello out the tone and remove the gurgling. I used little Dynomax 6" glasspacks from Jegs. I cut off my mufflers and had the packs welded on with tips cut and turned angled with the side of the car. not out the back. cant see anything unless you look under the car. My friend has a 1997 Viper GTS and he says he wishes his car sounded as good as mine it sounds like a real Chevy now.. But as always unless you hear it for yourself you wont be happy. I went to lots of Vette shows and no after market sounds as good as Glasspacks on mine. Remember though they will rust if you dont keep a good coat of high temp paint on them. Good luck!
Old Feb 2, 2004 | 09:32 PM
Bill Dearborn's Avatar
Bill Dearborn
I ran Supertrapps on my 97. They have an inner core surrounded by glass packing. You adjust the sound by changing the number of discs at the end. On the street I ran with 12 discs and on the track I pulled them all off. Even with the discs in I had a tremendous drone from 1600 rpm to 2000 rpm that would kill your hearing after a while. The whole interior would vibrate from the sound.
Bill
Old Feb 2, 2004 | 10:38 PM
SR71's Avatar
SR71
Default Re: Glasspacks??? (Bill Dearborn)
sure there are glasspacks out there for the C5....they are called borla stingers. :D
Old Feb 3, 2004 | 06:37 PM
mjb929rr's Avatar
mjb929rr
Default Re: Glasspacks??? (SR71)
I have owned several sportbikes in the past and have put aftermarket exhaust on them. Every exhaust i bought was the race version and was identical to a glasspack internally. I have contemplated the idea of adding them to my car since the slp lm is so damn loud! :cuss
To Glasspacks???
