Seat removal - help
Old Feb 2, 2004 | 07:32 PM
JCR's Avatar
JCR
Default Seat removal - help
How do you get at the front mounting nuts that holds the seat rails in place. Appreciate any quick tips.. Thanks ..
Old Feb 2, 2004 | 07:48 PM
allanlaw's Avatar
allanlaw
Default Re: Seat removal - help (JCR)
You must remove the plastic caps from the front of the seat rail.
Old Feb 3, 2004 | 10:06 AM
kromberg's Avatar
kromberg
Default Re: Seat removal - help (allanlaw)
There is a little plastic push/pull pin that holds the cover to the rail :)
Keith
Old Feb 3, 2004 | 11:13 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Re: Seat removal - help (kromberg)
there is a cover over the front nuts... it is an "L" shaped cover..
in the center is a pin head, almost like the head of a dry wall toggle bolt... when you pull this pin out.. ( about 3/8 in. ) it will collapse the wings behind it...
then you must slide the whole "L" shaped cover forward to the front of the car...there is a clip under the cover the clip is about 1/2 long... slide the cover about 1/2 in forward and it will come right off... if you try to pry the cover off before sliding forward.. you will tear the clip off..
Some times more information is better than less... even if it is over kill..
Old Feb 3, 2004 | 11:15 AM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Keith
:iagree: and just to add something, after you remove the little push pull pin you need to slide the plastic cover towards the front of the car.
Old Feb 3, 2004 | 11:16 AM
Flyin'Brian
Cruise-In I Veteran
Default Re: Seat removal - help (Flyin'Brian)
Evil-Twin...you beat me to it :lol:
Old Feb 3, 2004 | 06:46 PM
JCR's Avatar
JCR
Default Re: Seat removal - help (Evil-Twin)
Thanks guys .. Great tips . Looked a little tricky at first , but got it now. Piece of cake once you know!!
To Seat removal - help
