shut down RATTLE??????
Old Feb 2, 2004 | 09:43 PM
dogdoc97's Avatar
dogdoc97
Default shut down RATTLE??????
just got home my NEW '04 Manny 6 speed; heard "the" noise. Ironically, just read an article in Corvette quarterly where a woman described this noise like dieseling.....the response was that while not desirable it is normal and called "shut dwon rattle", the inertia of the gears and tranny suddenly stopping, any thoughts, DOGDOC :confused: :mad
Old Feb 2, 2004 | 09:59 PM
1redc5's Avatar
1redc5
Default Re: shut down RATTLE?????? (dogdoc97)
I know what your talking about, I was an import freak until about 3 years ago when I realized it was pointless in spending $20000 to make a $10000 car go fast. So I bought a Vette and started with a fast car. Now, how to get that $20000 again... hmmm. But anyway I noticed all those little things the rattle when you start and shut down the v8 and even odd idleing at times, gear whine all that good stuff. Perfectly normal from what im told.
Old Feb 2, 2004 | 11:25 PM
BlackMagicC5's Avatar
BlackMagicC5
Default Re: shut down RATTLE?????? (1redc5)
Its normal. You may notice that it does it only when you are in neutral with the clutch out. Try shutting down with it in first and your foot on the clutch. :cheers:
Redshift's Avatar
Redshift
Platinum Supporting Vendor
Just press the clutch in before you turn the engine off and the noise goes away ;)
Old Feb 2, 2004 | 11:36 PM
C5Luv'R's Avatar
C5Luv'R
Default Re: shut down RATTLE?????? (Redshift)
I'm pretty sure that is the throwout bearing making that noise. Normal on C5s. Don't worry.
Old Feb 3, 2004 | 12:21 AM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
It is normal like evryone said. i think they even have a little segment about it in the C5 video. Just try pushing in the clutch when you shut the car down. It won't go away completely but it helps. Kaley
Old Feb 3, 2004 | 07:18 PM
victor00c5's Avatar
victor00c5
This is total normal. I have a 2000 6-speed , went to my dealer. They faxed me a service document #1297757. This discribes the problem to a tee !
:eek:
Old Feb 3, 2004 | 11:20 PM
BlackMagicC5
Default Re: shut down RATTLE?????? (victor00c5)
:eek:
What exactly did they say causes it?
Old Feb 4, 2004 | 01:13 PM
ersatz928's Avatar
ersatz928
Default Re: shut down RATTLE?????? (KillerVette99)
The noise is caused by the gears rattling on the mainshaft. The ATF (Auto Tranny Fluid) that is used inside the gearbox does not dampen this noise like heavy weight gear oil, traditionally used in manual trannys. GM (and other manufacturers) use ATF in manual gearboxes to reduce frictional and "pumping" losses in the tranny, increasing fuel economy. It is "normal" for the C5, but not an acceptable condition for a $40K car, not even a $10K Hyundai does this!!
[Modified by ersatz928, 12:13 PM 2/4/2004]
Old Feb 4, 2004 | 03:58 PM
Heretic's Avatar
Heretic
Default Re: shut down RATTLE?????? (ersatz928)
If you want a quiet car buy a Benz, if you want a sports/muscle car the Corvette is a bargain.
It costs 1/3 to 1/2 of is closest competitors, I will forgive a few noises.
Old Feb 4, 2004 | 04:47 PM
joe03z06's Avatar
joe03z06
Default Re: shut down RATTLE?????? (Heretic)
push in the clutch and you wont hear the noise! :cheers:
Old Feb 4, 2004 | 05:59 PM
victor00c5's Avatar
victor00c5
Here it is straight from the you know whats mouth!
GM Doc. id # 1297757
Neutral Rattle
There are often concerns of rattel while idling in neutral with the clutch engaged. This is related to the changes in angular acceleration described earlier. This is a light rattle, and once again , vehicles with dual mass flywheels will have reduced noise. If the engine is shut off while idling in neutral with the clutch engaged, the sudden stop of the engine will create a rapid change in angular acceleration that even dual mass flywheels can not compensate. Because of the mass of all the components, this will create a noise. This type of noise should not be heard if the clutch is released ( Pedal pushed to the floor).
Thats what they say :rolleyes:
Old Feb 4, 2004 | 10:04 PM
codeblue's Avatar
codeblue
Default Re: shut down RATTLE?????? (joe03z06)
:iagree: push in the clutch.
Old Feb 5, 2004 | 12:38 AM
jl240z's Avatar
jl240z
This is why I like this site so much. There is a lot of practical experience out there. I bought my hardtop used and didnt hear the noise on the test drive. I was so excited about buying this car the rear end could have fallen out and I probly wouldnt have noticed. Well maybe thats a bit of an overstatement, but I didnt hear the noise until I drove it home and parked it carefully in the garage and then I heard it and experienced the usual panic. After I posted the same question you did I was put at ease with the answer and was once again content and at peace with the world. Then came the rocking seat but thats another story. So continue to enjoy the forum its an great place to learn stuff :thumbs: :steering:
Old Feb 7, 2004 | 08:48 AM
STONEjam's Avatar
STONEjam
Gee. A Corvette that rattles? That's a new one.
:lolg:
To shut down RATTLE??????
