(+) batery cable replacement
Old Feb 2, 2004 | 10:19 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
Default (+) batery cable replacement
I need to replace my positive battery cable.
my old battery leaked acid on to it and I think I should replace it.
Has anyone done it and if so what is involved.
Thanx
Dean
Old Feb 3, 2004 | 09:31 PM
devo's Avatar
devo
Default Re: (+) batery cable replacement (devo)
no one has ever done this?
Old Feb 3, 2004 | 10:01 PM
LoneStarFRC's Avatar
LoneStarFRC
I haven't done this yet but I've read through the procedure in the shop manual. Looks like a pain in the keester.
Robert
Old Feb 3, 2004 | 10:21 PM
mapman's Avatar
mapman
Positive Battery Cable Replacement
1. Remove the Battery:
Disconnect the negative battery cable,
Disconnect the positive battery cable,
Remove the battery hold down retainer bolt and retainer,
Remove the battery.
2. Remove the Battery Tray:
Remove the battery tray bolts,
Remove the battery tray.
3. Positive Cable Replacement:
Open the stud cover on the fuse/relay center,
Remove the positive battery cable nut from the fuse/relay center stud,
Remove the positive battery cable lead from the fuse/relay center stud,
Remove the heat shield retainer at the upper plenum,
Remove the battery heat shield retainer and the battery heat shield,
Remove the right rear spark plug wire,
Remove the battery cable clips,
Remove the battery cables from the engine wiring harness insulator,
Raise and suitably support the vehicle,
Remove the positive battery cable terminal nut and terminals from the starter solenoid,
Lower the vehicle,
Remove the positive battery cable.
The procedure and drawings are in Section 6 of the Shop Manual. There have been Corvette magazine articles/threads on damage to wiring/HVAC/etc from leaking batteries, so you might check those as well. I purchased my Shop Manual from Ken Fichtner, a Shop Manual is inexpensive and the best "tool" you can get.
http://temp.corvetteforum.net/c5/ken...rtspage1.shtml
Old Feb 4, 2004 | 10:07 PM
devo's Avatar
devo
Default Re: (+) batery cable replacement (mapman)
cool!
thank you very much
Dean
To (+) batery cable replacement
