High flow cat placement and efficiency
Old Feb 2, 2004 | 11:02 PM
High Vettelocity's Avatar
High Vettelocity
Default High flow cat placement and efficiency
I recently got LG longtube headers with metal matrix cats. The car runs great. I would never go back to stock. However there is one small problem. The car definately smells of unburned hydrocarbons now.
I was under the car today looking at all the slip joints. It looks like all the large and small ends are in the right order to just move the cats up in front of the Xpipe. The clearance looks tight, and it might require turng a clamp or two around so the bolts don't touch. But I think it will work.
I've been told the cats will work at temperatures as low 140 degrees.
So here is the questions. Has anyone done this? Will moving the cats 2 feet closer to the motor increase their temp and eliminate the smell? I Just don't want to waste the time if it won't make a difference. Thanks in advance.
Old Feb 2, 2004 | 11:37 PM
Cary's Avatar
Cary
Default Re: High flow cat placement and efficiency (High Vettelocity)
Call Lou at 1-877-LGMotor. He is always glad to help LGM customers over the phone.
[Modified by Cary, 10:38 PM 2/2/2004]
Old Feb 3, 2004 | 02:42 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: High flow cat placement and efficiency (Cary)
:iagree: :nono:
Old Feb 3, 2004 | 12:12 PM
C5XTASY's Avatar
C5XTASY
I remember reading an article about X-pipes that said they are much more efficient if mounted upstream (in front of) of the cats. I suspect the scavenging effect is much better without any restriction. I didn't realize that the LGs were designed that way. I now have a question in addition to the above (question): Would changing the order of the X-pipes and cats cause power gains to be decreased?
Ed
[Modified by C5XTASY, 11:13 AM 2/3/2004]
Old Feb 3, 2004 | 01:57 PM
myblackC5's Avatar
myblackC5
look for air leaks! air leaks will make it run rich.
:chevy
Old Feb 3, 2004 | 02:09 PM
RWhite's Avatar
RWhite
From NAPA, you can buy some nice looking clamps that surround the entire pipe at the joint and will seal good . A little high dollar but they work.
They are about 4-5 inches long, wrap around the joint, extending past the joint on either end of it 1-2 inches. They have a very nice looking clamping action provided by two husky looking bolts.
At one of the local shops (maybe Lou's or MMT), I saw some of these.
Old Feb 3, 2004 | 05:41 PM
larrysb's Avatar
larrysb
I would imagine that moving them closer to the engine will improve the cats effectiveness. I don't know for sure, I haven't done this. However, if you look at all the engineering that's done, the car makers really want those cats as close to the exhaust manifold as possible. GM's C6 cats are going to be really close to the engine as they are on the Northstar V8's.
The other thing to keep in mind is the car probably needs a careful dyno tuning since you have really changed it's flow dynamics with the headers and high-flows. If the engine is running rich, it may be dumping more fuel on the cats than they can handle, which will cause them to overheat and fail in addition to making funky odors.
To High flow cat placement and efficiency
