How much HP is too much?
Old Feb 3, 2004 | 02:10 AM
LBear's Avatar
LBear
Default How much HP is too much?
How much HP can a stock C5 motor take?
I know the crank is cast iron instead of forged but what is the weak link in that motor?
Old Feb 3, 2004 | 03:12 AM
cfi_luz's Avatar
cfi_luz
Default Re: How much HP is too much? (pettrix)
The weakest link are the stock rod bolts. Once these are replaced you should be good to 500+HP depending on application. Detonation will kill your stock pistons though, so if boosting best to go forged up front if possible.
Old Feb 3, 2004 | 03:14 AM
kumar75150's Avatar
kumar75150
Default Re: How much HP is too much? (cfi_luz)
CFI LUZ hit it on the head.
Rods and crank will handle a lot of abuse.
Head bolts are weak and then the pistons are not great for FI applications.
Old Feb 3, 2004 | 11:33 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: How much HP is too much? (kumar75150)
:iagree: :thumbs:
Old Feb 3, 2004 | 04:22 PM
ArKay99's Avatar
ArKay99
:iagree:
Also pre 2001 rod bolts are only good to around 6200 rpm's reliably.
Old Feb 3, 2004 | 04:26 PM
niphilli2's Avatar
niphilli2
Default Re: How much HP is too much? (ArKay99)
Yep: Rodbolts, Pistons, and headbolts are the weakest.
Old Feb 3, 2004 | 05:16 PM
CanoeU's Avatar
CanoeU
Default Re: How much HP is too much? (niphilli2)
:iagree:
Old Feb 3, 2004 | 05:18 PM
Stang Killer's Avatar
Stang Killer
http://www.ls1tech.com/forums/showthread.php?t=135309 http://www.ls1tech.com/forums/showthread.php?t=113950
Hope that helps answer some of your questions.
To How much HP is too much?
