LT header instal - welding or not?
Old Feb 3, 2004 | 08:42 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Default LT header instal - welding or not?
Hi Everyone!
I have been following several recent header install threads and are rather confused about the Long tubes install and any welding that may be needed. I have the factory CATs and a magnaflow X pipe. I want either FLP's or TPIS headers and I want to keep the factory CATs. Do I need to weld to install either of these headers?
I am sure I want Long tubes, I have an upcoming Magnusson install that will benefit greatly from them. As always, your help is draining my cash and I could not be happier :jester
[Modified by Ragtop_Rob, 7:42 AM 2/3/2004]
Old Feb 3, 2004 | 08:58 AM
WestCoastCorvette's Avatar
WestCoastCorvette
Supporting Vendor
Default Re: LT header instal - welding or not? (Ragtop_Rob)
The TPIS will need to be welded. There is slip pipe that slides into the header side and gets welded to the cat side. Any muffler shop should be able to hndle do this.
Paul
Old Feb 3, 2004 | 10:08 AM
kromberg's Avatar
kromberg
As far as I know, the FLP exhaust system is the only one that does not require welding. This is because their system replaces just about everything to the catback.
Keith
Old Feb 3, 2004 | 11:11 AM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: LT header instal - welding or not? (kromberg)
Keith
Along with Stainlessworks and Kooks and the LG Longtubes
Old Feb 3, 2004 | 01:41 PM
fsuforever's Avatar
fsuforever
well let me clear something up for you so u wont be confused anymore about welding or not to weld If you want to keep your CATSon your car & u go with longtubes u will require for you to weld but if you delete your cats like i did u do NOT have to weld them & i do have tpis long tubes in
Hi Everyone!
Old Feb 3, 2004 | 02:05 PM
lowdowndirty's Avatar
lowdowndirty
Default Re: LT header instal - welding or not? (fsuforever)
Or you can replace your factory cats the easy way and purchase a system w/ high flow cats. The new Dynatech's come with everything you need to replace everything except the mufflers. Also, TPIS and Kooks all have complete systems that replace everything from the over axle tubes forward and require no welding. Chris.
Old Feb 4, 2004 | 07:18 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Default Re: LT header instal - welding or not? (lowdowndirty)
THANKS Everyone!! If was not chicken I would just delete the CATS :D , However it looks like I am doing High flow CATS. I guess I will need to sell my magnaflow X pipe ,as the systems I have seen come with X pipes already
Just need to get these ordered and installed before the Spring Skyline Drive Cruise
THANKS AGAIN EVERYONE!! :auto:
[Modified by Ragtop_Rob, 6:20 AM 2/4/2004]
Old Feb 4, 2004 | 05:31 PM
AFVETTE's Avatar
AFVETTE
FLP's are plug and play, bolt right in. They provide everything in their kit.
Tom
Old Feb 4, 2004 | 05:43 PM
02blueelectron's Avatar
02blueelectron
i am having my slp headers + hi flo cats being installed today. it is complete bolt on to my magnaflow xpipe system w/slp headers slip fit to slp h-pipe to slp hiflo cats (exit size is stock) to slip fit to the magnaflow xpipe
To LT header instal - welding or not?
