clutch help
Old Feb 4, 2004 | 09:58 PM
wango tango's Avatar
wango tango
Default clutch help
I'm going to put a clutch in my 01 zo6. Question is, should I use my spec stage 3 carbon from my ta? should i change the disc to the stage 3i? do pressure plates wear out?
I also have an aluminum fidenza flywheel with about 1500 miles on it. Can you get those resurfaced anywhere? I thought I read that Fidenza can put material back on them. How do these work with regards to resurfacing?
Finally, should I change the slave? The master? I am definately doing the drill mod.
The car makes ~ 428 rwhp, and I'll be running a 125 or 150 shot on ET streets.
10's here we come!
