just wanted to see if anyone on the forum has did this install themselves ? can u get take out the servo without having to pull the transmission out ? anyboy i got a transmmision man thats gonna do the work he just doesnt know if the servo can be acssesible without pullling the trans
I'm glad you found this marvelous transmission mod..EVERY A4 should have it!! :smash:Anyway..You can call my trans tech..he's done many of these TRANSGO installs and he is a CF member..Call Steve Atkins at www.eastcoasttransmissions.com He CAN help you with the install:D
what kind of trans fluid should i buy when i let this mechanic tackle this project ? i see people are using this Amsoil ATF i guess i will try it i think i put well i can t remember what i put in it when the 3200 yank & the gear when in
I have gone the Amsoil, Redline, M1 ATF route, but I'm back to genuine GM Dexron III ATF from the Chevy dealer ($2.60/qt.)
Why?
You should run an ATF cooler anyway to keep the temps below 200F. I'd rather change my ATF more often (every two years) and use genuine GM Dexron III instead of using ultra-expensive synthetic ATF and leave it in there for years. Also some, not many, but some 4L60Es do not like synthetic ATF and start to slip. many posts on the full size chevy forum and on the Pontiac GTP forum. many went back to GM Dexron III.
When I switched my OEM Dexron out for M1 ATF in my 96 LT1 Vette, shifts became very soft under part throttle. Didn't like that at all. if you have to go the synth route, I would go with Redline as my first choice and Amsoil as my second choice.
