Re: HELP: no break lights on rigth side (99 vett babycar)
been there and done that. does your turn signal lights go out intermittently?
i had the same problem on my 2000 coupe. had to have the hazard switch replaced as well as the turn signal device. cost: $50 for hazard switch $249 for turn signal $500 labor. if you can do it yourself or know someone, do it. dealers get like almost $100 labor. fixed my problem, though.
