Mallory window switch?
Old Feb 5, 2004 | 10:09 PM
babala65's Avatar
babala65
Default Mallory window switch?
I have A Mallory window switch PN. 628 and A Nos kit # 05177 I have eveything hooked up but I'm not sure where to connect the 2 orange wires I know one goes to ground
and the other to ??? :confused: :confused: does anyone have this same set up? :banghead: :banghead:
[Modified by babala65, 9:13 PM 2/5/2004]
Old Feb 6, 2004 | 02:36 AM
SQEZN BI's Avatar
SQEZN BI
Default Re: Mallory window switch? (babala65)
Im sure they are the same as any other window switch if one is ground the other must go to tach lead out of pcm , 2000 and up pin 10 white wire uot of pcm. Do search in archives under shiftlight install there is another way to get a tach lead under the dash that is faster than removing wheel well cover.
Old Feb 6, 2004 | 12:12 PM
babala65's Avatar
babala65
Default Re: Mallory window switch? (SQEZN BI)
I already have A good tach signal I just need to know where the 2 orange wires go. They are the on/off wires. :yesnod:
Old Feb 6, 2004 | 02:02 PM
babala65's Avatar
babala65
I think I got it! They hook up to the ground side of the solenoids, now I think I may have A different problem.I just posted it in the "Induction/Nitrous" thread. :confused: I just talked to the tech's at Holley and he told me to "be real careful with that kit! thats for the f body cars the fuel will not keep up with the demand it runs real lean on the dyno so we had to shut it down"
I already have the kt. installed in my car but have not used it, waiting for the snow to thaw! I bought the kit through e-bay and they listed it as the kit for the corvette 97-2004. Has any one had any problems with this kit?? :confused: :confused: :banghead: :banghead:
[Modified by babala65, 1:06 PM 2/6/2004]
To Mallory window switch?
