electric water pump (worth it?)
Old Feb 6, 2004 | 11:23 AM
MAGRED2001VETTE's Avatar
MAGRED2001VETTE
Default electric water pump (worth it?)
AFTER H/C, ASP pulley, and TPIS LT:
Is the electric water pump worth it on this kind of set up? I'm woundering if it is like the aftermarket T-body and MAFS, you won't gain much.
Old Feb 6, 2004 | 11:55 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: electric water pump (MAGRED2001VETTE)
If the intent was to gain HP, I would not waste money on this mod. If the intent was to increase the cooling, I would consider it...
VR :cheers:
[Modified by vetterdstr, 8:57 AM 2/6/2004]
Old Feb 6, 2004 | 02:22 PM
kumar75150's Avatar
kumar75150
NO
Old Feb 6, 2004 | 03:21 PM
SpinMonster's Avatar
SpinMonster
Default Re: electric water pump (kumar75150)
get gears next---4.10's
Old Feb 6, 2004 | 03:22 PM
dahoof's Avatar
dahoof
Default Re: electric water pump (vetterdstr)
VR :cheers:
:iagree:
Old Feb 6, 2004 | 03:39 PM
MAGRED2001VETTE
Thanks guys for your input....all seem to agree!
Old Feb 6, 2004 | 03:44 PM
C5XTASY's Avatar
C5XTASY
Default Re: electric water pump (dahoof)
:iagree:
One thing I have never understood about this mod, as far as gaining power by going to an electrical rather than mechanical water pump, is the fact you still must create the power to run the pump. That power is not created by the alternator at 100% efficiency, nor used by the water pump's electric motor at 100% eficiency. There are significant losses associated both with producing, and utilizing, that power. I can't speak for the increase in cooling, I just question the supposed power gain. Maybe there's something I'm not aware of in the design or use of these pumps. Doesn't make any sense to me. :confused:
Ed
[Modified by C5XTASY, 2:45 PM 2/6/2004]
Old Feb 6, 2004 | 04:28 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: electric water pump (C5XTASY)
I don't have one, but it works on the same prinicpal as the ud pulley; less parasitic loss. You don't gain any power from the motor, but you use less of what you have to turn the accessories. I'm pretty sure they're worth 5-7 rwhp now that the motor doesn't have to turn the water pump.
Old Feb 6, 2004 | 06:03 PM
pdd000's Avatar
pdd000
Default Re: electric water pump (Cobra4B)
im gettin one. i'll take the 5 hp gain and run cooler to boot :yesnod:
Old Feb 7, 2004 | 01:55 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: electric water pump (pdd000)
:thumbs: :cheers:
Old Feb 7, 2004 | 02:51 AM
vetteman21's Avatar
vetteman21
heres a good writup on it. looks like 6rwhp
http://www.ls1howto.com/index.php?article=27
[Modified by vetteman21, 1:52 AM 2/7/2004]
Old Feb 7, 2004 | 12:03 PM
corvettebob1's Avatar
corvettebob1
:iagree:
Ed
I agree 1000% :iagree: :iagree: :iagree:
There is no free lunch...... :sad:
Old Feb 8, 2004 | 03:49 AM
Cobraeater's Avatar
Cobraeater
I wanted to test the Meziere EWP out back-to-back to see if there were any hp gains, so I went to MMT in Dallas on Saturday and dynoed with the stock water pump and then the Meziere.
I gained 0 hp and -1 torque going to the Meziere!
Here's the stock water pump dyno graph.
http://www.cobraeater.cz28.com/cgi-b...ump%20Dyno.jpg
And here's the Meziere dyno.
http://www.cobraeater.cz28.com/cgi-b...EWP%20Dyno.jpg
Here's a graph with the best runs from the stock water pump and the Meziere.
http://www.cobraeater.cz28.com/cgi-b...re%20After.jpg
As you can see there was no hp to be gained, but the cooling and looks are something most people would go for.
With the stock pullies instead of the ASP pullies I might have seen some small gains, but I would consider the ASP to be the better buy.
Old Feb 8, 2004 | 04:32 AM
Darkness's Avatar
Darkness
Default Re: electric water pump (Cobraeater)
Damn, those differences are too small to tell if there's an increase on it. The difference between same setups on different runs is bigger some times. :crazy:
Old Feb 8, 2004 | 09:13 AM
C5XTASY's Avatar
C5XTASY
Makes sense to me. :yesnod:
To electric water pump (worth it?)
