MY C5 IS MISSING!!
Old Feb 6, 2004 | 08:16 PM
wolley 1's Avatar
wolley 1
Default MY C5 IS MISSING!!
Help...after 40k miles decided to get rid of the old plugs and wires. Went with the MTD wires. Now at idle I have a sopadic miss...maybe one hiccough every minute or so. Checked to ensure the wires were pushed securely onto the plugs and fuelrails. Can they scope it to see if a cylinder is misfiring? I realize it could be many things...help
Old Feb 6, 2004 | 08:20 PM
jmX's Avatar
jmX
Default Re: MY C5 IS MISSING!! (wolley 1)
You can buy a scanner from tons of places that'll tell you what cylinder is missing. Autotap, EFILive, etc should all work.
Old Feb 6, 2004 | 08:23 PM
BADBLACK99's Avatar
BADBLACK99
Check to make sure no wire hit a header tube and got burnt. That happened to me and I found it was #7 by the brake booster was touching I could not tell by visual inspection until I removed it and saw the burn. Also check to make sure none of your plugs had the porcelin cracked somewhere. I have been through both of these things before when I had a problem like yours.
Old Feb 6, 2004 | 08:36 PM
wolley 1's Avatar
wolley 1
Thanks for the quick replies....I'll check it all!! :yesnod:
Old Feb 6, 2004 | 09:31 PM
SteveL2's Avatar
SteveL2
Whew, I'm just glad to read it's only a firing problem. With your topic, I thought you meant someone stole your car! :eek:
Old Feb 6, 2004 | 09:55 PM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
Default Re: MY C5 IS MISSING!! (SteveL2)
That's what I thought too.
Old Feb 7, 2004 | 05:36 AM
1fastmfc5's Avatar
1fastmfc5
Default Re: MY C5 IS MISSING!! (Corvette SSX)
i was going to suggest that you put a picture of it on the back of a milk carton :lolg:
Old Feb 7, 2004 | 01:14 PM
myblackC5's Avatar
myblackC5
Default Re: MY C5 IS MISSING!! (1fastmfc5)
1fastmfc5.............. :rofl:
To MY C5 IS MISSING!!
