spun bearing
Old Feb 6, 2004 | 10:41 PM
jobberone's Avatar
jobberone
jobberone
Default spun bearing
spun main. should block be line bored to try and prevent this from happening again. no known cause as no/low oil, overheat, overrev, yada.
Old Feb 7, 2004 | 12:59 AM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: spun bearing (jobberone)
How about a high G corner. Plenty of people have starved the bearings because they were taking a long high G corner and weren't running an extra quart of oil in the pan.
Bill
Old Feb 7, 2004 | 09:43 AM
jobberone's Avatar
jobberone
jobberone
Default Re: spun bearing (Bill Dearborn)
Hi, I'm not sure what caused the failure. Typically the crank "touches" an area on a bearing, there is heat build up due to friction, and the bearing fails. Of course if you run the engine without oil for whatever reason then the chance for failure goes up. The situation you describe is running it without oil special circumstance. My question is if you buy an engine with a known spun bearing failure should you line bore it on general principal? Thanks
Old Feb 7, 2004 | 10:18 AM
'97 C5's Avatar
'97 C5
Absolutely, yes
Old Feb 7, 2004 | 10:22 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Default Re: spun bearing ('97 C5)
Absolutely, yes
:iagree: No question about it!
Tom :steering:
Old Feb 7, 2004 | 03:53 PM
jobberone's Avatar
jobberone
jobberone
Default Re: spun bearing (TCW)
What are you guys paying to line bore a cast iron block with minimal machine work only to do that? Thanks
Old Feb 7, 2004 | 04:47 PM
racetchr's Avatar
racetchr
Just had my engine rebuilt, and this machine work was $225 for mains.
Old Feb 8, 2004 | 06:32 PM
rodknock's Avatar
rodknock
Default Re: spun bearing (racetchr)
without a doubt :iagree:
Old Feb 8, 2004 | 06:35 PM
BlackZ06's Avatar
BlackZ06
Quote:
"What are you guys paying to line bore a cast iron block with minimal machine work only to do that?"
The LSx block is aluminum with iron sleeves for the cylinders.
Steve
To spun bearing
