Need HELP Identifying A Noise
Old Feb 7, 2004 | 08:04 PM
Viprklr's Avatar
Viprklr
Default Need HELP Identifying A Noise
Hi all,
When I go over a speed bump I get a squeeking noise from the front right area of the car. Visually I can't see anything and was wondering what might be making the noise. Shocks were replaced about 2 years ago with Bilstein's. Everything else is stock regarding suspensions items. Car is almost 4 years old.
Thanks for any help.
Matt
:cheers:
Old Feb 7, 2004 | 09:39 PM
JCR's Avatar
JCR
Default Re: Need HELP Identifying A Noise (Viprklr)
Try lubricating the sway bar bushings
Old Feb 8, 2004 | 12:07 AM
bmathews's Avatar
bmathews
Default Re: Need HELP Identifying A Noise (JCR)
:iagree: :iagree: :iagree: :thumbs: :thumbs: :thumbs:
Old Feb 8, 2004 | 11:27 AM
JC in XTC5's Avatar
JC in XTC5
I believe the sway bar bushings have a lining that makes contact with the bar that should not be lubricated as it could make the problem worse (although more an annoyance than a problem).
Check the bolts around the bushings and suspension points for proper tightness. The may have loosened up and be responsible for the noise.
To Need HELP Identifying A Noise
