Just curious how much you mix and if it's cat friendly?
Maybe I'll just get some Torco :auto:
I was running 2, sometimes 3 gallons of toluene per tank in the Dallas summers. Made a pretty significant difference in my case. No pinging, no KR, even when it was over 100 degrees out.
CAT safe as far as I know, but pretty dangerous stuff to be handling. It is hard to buy in some places too, as it is used in Meth labs and by huffers.
Here are a few sites to help determine how much you should be mixing:
http://www.idavette.net/hib/fuel/page2.htm http://www.elektro.com/~audi/audi/toluene.html
There is one other site that has a calculator, but I can't find the link :(
F
F
I was using xylene in a 1:10 mix. DO NOT use this stuff if you are going to the dyno. I almost killed everyone in the shop, as this stuff smells toxic. Outside wasnt as issue, cats were okay, and it prevented detonation.
CP
close
- Member SinceAug 2000
- LocationSpring Texas
Liked:1,322 Times in 679 Posts
These aromatics (toluene and xylene) have high octane and low vapor pressure. Adding a lot will distort the distillation profile of the fuel. Unburned hydrocarbons in the exhaust gas are usually caused by incomplete combusion of aromatics.
http://www.faqs.org/faqs/autos/gasoline-faq/ http://www.gnttype.org/techarea/misc/octanebooster.html http://www.gnttype.org/techarea/misc...explained.html
Toluene is a very safe choice because it is one of the main octane boosters used by oil companies in producing ordinary gasoline of all grades. Thus if toluene is indeed harmful to your engine as feared, your engine would have disintegrated long, long ago since ordinary pump gasoline can contain as much as 50% aromatic hydrocarbons.
Toluene is a pure hydrocarbon (C7H8). i.e. it contains only hydrogen and carbon atoms. It belongs to a particular category of hydrocarbons called aromatic hydrocarbons. Complete combustion of toluene yields CO2 and H2O. This fact ensures that the entire emission control system such as the catalyst and oxygen sensor of your car is unaffected. There are no metallic compounds (lead, magnesium etc), no nitro compounds and no oxygen atoms in toluene. It is made up of exactly the same ingredients as ordinary gasoline. In fact it is one of the main ingredients of gasoline.
Toluene has a RON octane rating of 121 and a MON rating of 107, leading to a (R+M)/2 rating of 114. (R+M)/2 is how ordinary fuels are rated in the US. Note that toluene has a sensitivity rating of 121-107=14. This compares favorably with alcohols which have sensitivities in the 20-30 range. The more sensitive a fuel is the more its performance degrades under load. Toluene's low sensitivity means that it is an excellent fuel for a heavily loaded engine.
Toluene is denser than ordinary gasoline (0.87 g/mL vs. 0.72-0.74) and contains more energy per unit volume. Thus combustion of toluene leads to more energy being liberated and thus more power generated. This is in contrast to oxygenated octane boosters like ethanol or MTBE which contain less energy per unit volume compared to gasoline. The higher heating value of toluene also means that the exhaust gases contain more kinetic energy, which in turn means that there is more energy to drive turbocharger vanes. In practical terms this is experienced as a faster onset of turbo boost.
Chevron's published composition of 100 octane aviation fuel shows that toluene comprises up to 14% alone and is the predominant aromatic hydrocarbon. Unfortunately composition specifications for automotive gasoline is harder to pin down due to constantly changing requirements.
Q: Will toluene damage my engine or other parts of my car?
A: A 5 or 10% increase in the aromatic content of gas will most likely be well within the refining specifications of gasoline defined by ASTM D4814, which specify an aromatic content of between 20% and 45%. What this means is that if the 92 octane gas that you started off with had an aromatic content of say 30% and you increased it by 10% to 40% you would still be left with a mix that meets the industry definition of gasoline. So the above question would amount to: "Will gasoline damage my engine or other parts of my car?"
Even in the unlikely event that the 92 octane gas has a aromatic content of 45% the resulting mix would still be within the bounds of gasoline sold in other countries.
Q: Isn't toluene an extremely toxic substance?
A: The common perception of toluene's toxicity far exceeds reality. Fortunately there is an ample body of information available that specifically addresses this question. Toluene is more toxic than gasoline but it is certainly not agent orange or cyanide.
Mobil's spec sheet for toluene even goes as far as saying that "Based on available toxicological information, it has been determined that this product poses no significant health risk when used and handled properly."
