Paging mintub owners
Old Feb 9, 2004 | 09:39 AM
kromberg's Avatar
kromberg
Default Paging mintub owners
I have a couple of questions for all of you that have tubbed your car. I am very seriously thinking about tubbing my car, but I would like to gather a little more info first :)
1) Did you use a vendors kit or did you use your existing panels to modify, move, and patch them?
2) What size wheels and offsets are you running?
3) Are you using and type of travel limiter and/or shock relocator?
Thanks,
Keith
Old Feb 9, 2004 | 01:21 PM
C5 YA's Avatar
C5 YA
Default Re: Paging mintub owners (kromberg)
I had some similar questions.
http://forums.corvetteforum.com/zerothread?id=733101
Old Feb 9, 2004 | 02:00 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I bought everything I needed from Lowes and only spent about $25.00, I have yet to do the wheel well liners but I'll worry about that when I'm closer to buying the 18 X 12 inch wheels :cheers:
Old Feb 9, 2004 | 02:25 PM
Guest
Guest
Posts: n/a
I have a Lingenfelter kit. I like the kit because it comes with the wider fender liners. I'm running an 18X12 with 335's on the rear. There were some clearance issues at first with the control arm. It seems to work real well. I would have done it differently if you could purchase the wider fender wells seperatley.
Matt
Old Feb 9, 2004 | 02:33 PM
NoMercy's Avatar
NoMercy
Default Re: Paging mintub owners (nitrosuzie)
I had someone else do the LPE kit with the shock mount mod. I am running 19/30/345 Pilot sports.
Old Feb 9, 2004 | 03:04 PM
kromberg's Avatar
kromberg
Default Re: Paging mintub owners (C5 YA)
Excellent info, thanks :) One question though, is everyone using stock offsets?
Keith
Old Feb 9, 2004 | 03:19 PM
YELLOHHH's Avatar
YELLOHHH
No kit. Cut, moved, and re-glassed the stock pieces.
I2) What size wheels and offsets are you running?
18x12 HREs. Not sure off the offset, but see pics at http://www.yellohh.com Gallery 2
Nope. I have Bilstien sports, and have had no problems. Only problem I have is the edges of the leaf springs rubbing the insides of the wheels, but that was solved by raising the rear back up some. I don't think shock relocaters would help this. But coil overs would. Gotta get some soon.
Old Feb 9, 2004 | 05:22 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: Paging mintub owners (YELLOHHH)
Kieth, I am interested in doing this mod as well. i do not plan on buying the kit. Let me know if you want to get together and do this to both cars at the same time. The only problem is I am in Florida until May. Kaley
Old Feb 9, 2004 | 07:56 PM
97C5ENVY's Avatar
97C5ENVY
I did my own tubbing. I posted a "How To" in the Tech Section if you wanted to see how I did mine. I'm running a 70mm offset, however the max offset you can go is 74mm.....without needing some type of shock mount relocation & shock travel limiter. There is one fourm member running a 78mm offset but he has issues with getting the rim on/off the car due to Rim/A-arm contact (which only occurs during full rear suspension droop).
On a side note I'm increasing my offset to 84mm once I get an alternative to the "LPE Shock Mount Relocation Bracket and Shock Travel Limiter" that I've been working on tested and verified. :D
Old Feb 10, 2004 | 09:00 AM
kromberg's Avatar
kromberg
Default Re: Paging mintub owners (97C5ENVY)
This is great info, thanks for passing it along. The stock offset of the rear wheels is +55mm correct?
Keith
Old Feb 10, 2004 | 09:02 AM
kromberg's Avatar
kromberg
Default Re: Paging mintub owners (2C5only21)
That sounds like a plan Kaley and May is the time frame I was thinking myself. Once you get back and are ready, let me know and we can work on the projects together :cheers:
Keith
Old Feb 11, 2004 | 12:47 PM
kromberg's Avatar
kromberg
I have another question: How was the carpet affected by adding the minitubs? Any modifications needs?
Keith
Old Feb 11, 2004 | 01:16 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Just finished locally.............
No kit, modified existing panels & fenderwells.
18x12 545 hres w/+74mm off set running 345/30/18 BFG DRs.
There is an area near the back mounting bolt for the plastic fender that juts out from the factory. I just shaped it with a box cutter & gave it a nice radius with the die grinder.
My rims just touch the A-arm bolted up w/o any limiters......I measured and found no need..........verified with the install!
looks like I have 3/4" before I hit the frame on the back of the tire.
Here is the links to my thread and my albumn with more pics
http://forums.corvetteforum.com/zerothread?id=748497
http://www.photohost.org/gallery/sho...si=allthrottle
Do it.........you will not be sorry.
The car rides great with the 345s on it :thumbs:
Old Feb 11, 2004 | 01:33 PM
JakeL's Avatar
JakeL
Keith
Keith + Kaley - Make that 3 of us! I know exactly zero about fiberglassing and stuff, but I'm sure willing to learn.
One question that's worthwhile to throw in the mix: How substantially different is the job with coupes versus hardtops?
-Jake
Old Feb 11, 2004 | 01:56 PM
kromberg's Avatar
kromberg
Default Re: Paging mintub owners (ALLTHROTTLE&NOBOTTLE)
Thanks for the info and pics ALLTHROTTLE&NOBOTTLE :)
Keith
Old Feb 11, 2004 | 02:10 PM
00TORCHCOUPE's Avatar
00TORCHCOUPE
Matt
Matt, did you install the kit yourself? Big job, how long, etc??
Old Feb 11, 2004 | 02:28 PM
kromberg's Avatar
kromberg
Default Re: Paging mintub owners (JakeL)
Hey Jake,
Would the May time frame work with you also? Sounds like we have a nice weekend project starting here :)
-Jake
After looking at the two howto docs that I know of, it looks like the only difference between a coupe and a hardtop is the coupe's roof holding brackets.
Keith
To Paging mintub owners
Old Feb 11, 2004 | 02:34 PM
JakeL's Avatar
JakeL
More than likely. I'll be at the Farmington ProSolo the first weekend of May, but I don't think I have any other plans beyond that. One thing I'm a bit curious about is the costs involved. LPE's Minitub kit is extremely expensive, but folks are saying they're doing it for just a few bucks in bondo and whatever.
Are there things they are not doing that the LPE kit provides? I won't be buying the larger wheels/tires for quite a while, but at least this way I'm prepared for when I need it.
Good to know. I am hoping to be able to keep the ability to store my top, if at all possible. Do you have a coupe, vert, or FRC? I know Kaley has an FRC at this point.
-J
Old Feb 11, 2004 | 03:21 PM
kromberg's Avatar
kromberg
The DIY versions/projects to not included a travel limiter and shock relocator. Becuase of this, it looks like the wheels will be limited to a +74mm offset. This offset will allow about 5/8" to 3/4" wider wheel without have the outer edge of the rim stick out any further than stock. From the pics I have seen, a 18"x12"wheel with a +74mm offset will have the outer edge of the wheel line up with the edge of the rear fender. If you want the outer edge of the rim to be inside the rear fender like a stock wheel, then a great offset would be needed along with the travel limiter and shock relocator.
If the factory panels/wells are cut correctly around the roof securing hardware, you should be able to still put your roof inside the car and secure it.
Keith
Old Feb 11, 2004 | 05:28 PM
Cruise-In V Veteran
NCM Ambassador
Mine fits in nice & tight, panel was moved right to the edge of the metal hat for these brackets. Look at my pics close and you can see this. :cheers:
