Thread repair?
Old Feb 9, 2004 | 02:20 PM
boost2much's Avatar
boost2much
Default Thread repair?
Is there a product or way that can repair the threads on both a nut and bolt without having to change the size of the threads or the nut. If I rethread the bolt, I will need a smaller nut correct? I don't want to use a smaller nut. :cheers:
Old Feb 9, 2004 | 02:58 PM
Billf6531's Avatar
Billf6531
Default Re: Thread repair? (boost2much)
Try a tap and die set to repair damaged nut and bolt threads. :)
Old Feb 9, 2004 | 03:03 PM
HWY318Runner's Avatar
HWY318Runner
Default Re: Thread repair? (Billf6531)
heliacoil kit. drill it out run the new threads in and call it good.
theres more to it than that but thats the premice of it.
Old Feb 9, 2004 | 04:23 PM
boost2much's Avatar
boost2much
Default Re: Thread repair? (HWY318Runner)
I've used the heli coil kit before but I need to use the same nut and stud since they are special. I guess I could retread the stud and heli coil the nut so they will work together. Is that possible? Also, would using JB Weld or something allow me to tap and die the stud and nut so they work together?
To Thread repair?
