McLeod Clutch??
Old Feb 9, 2004 | 03:15 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default McLeod Clutch??
2001 Z06, heads, cam, headers. Which McLeod should I go with?? I know I've seen this recenly, but I can't find it. Also, who would be best for install in the Ohio - Indiana area. Thanks guys.
Old Feb 9, 2004 | 03:22 PM
woosch's Avatar
woosch
Default Re: McLeod Clutch?? (binksZ06)
I went with the twin disk. :cheers:
Old Feb 10, 2004 | 05:23 PM
99 C5 Coupe's Avatar
99 C5 Coupe
If you're using your car for road racing I like the Mag Force twin Disc setup. I also went with the light flywheel, master cylinder and throw out bearing from McLeod. I think the Clutch/flywheel combo weights approx 18 lbs. All I know is it works great on the road course but isn't a friendly clutch to use on the street in stop and go traffic. Also, mine is a little noisy when at idle in neutral. Don't know if it was installed wrong or if that is the nature of a cintered iron disc set up?
Old Feb 10, 2004 | 08:53 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: McLeod Clutch?? (99 C5 Coupe)
Thanks guys. I emailed Dynotech to see if they'd take care of the install.
To McLeod Clutch??
