Crazy headlight alignment question
Old Feb 9, 2004 | 10:58 PM
Tormania's Avatar
Tormania
Cruise-In IV Veteran
Cruise-In V Veteran
Default Crazy headlight alignment question
I had some HIDs install on my car yesterday, but here is the funny thing. While I never really looked at the alignment of the headlights before now if the low beams are aligned the high beams are out of alignment and vice versa. My old g/f had the same lights installed on her 2002 over the summer and her alignment was just fine. Was my car just goofed up or what???
Old Feb 9, 2004 | 11:20 PM
jambrin's Avatar
jambrin
Default Re: Crazy headlight alignment question (Tormania)
I had this same problem when I changed the 9006 (low beam) bulbs to Sylvania aftermarket bulbs. I think the bulbs were not quite in the socket properly. This past weekend I installed a 9006 HID system and had a terrible time getting the Sylvanias out, even though they are supposed to just twist out! :mad: The new bulbs fit in just fine are seem to be aligned with the halogen high beams.
I would check the bulbs and make sure they twist in/out easily. If not, they could possibly be installed in the sockets crooked.
Old Feb 10, 2004 | 04:10 PM
Red Rag Top's Avatar
Red Rag Top
Default Re: Crazy headlight alignment question (jambrin)
:iagree:
I had the same problem. I thought the bulbs were installed correctly but on checking they were cocked in the housing
Old Feb 10, 2004 | 09:42 PM
Tormania's Avatar
Tormania
Cruise-In V Veteran
Default Re: Crazy headlight alignment question (Red Rag Top)
:iagree:
Thanks guys, when I get a chance I'll check to see if the lights are seated properly! :cheers:
Old Feb 10, 2004 | 09:48 PM
msuc5vette's Avatar
msuc5vette
What is the proper method for aligning the head lights anyway?
Is there a distance you should park from a wall and then try to line them up at a certain height?
Old Feb 10, 2004 | 10:06 PM
Tormania's Avatar
Tormania
Cruise-In V Veteran
Default Re: Crazy headlight alignment question (msuc5vette)
I have the service manuals and it spells out exactly how to do it. It involves parking 25' away from a wall, car on a flat surface, less then ½ a tank of gas and then certain landmarks measured on the way to be your guide for alignment. for me I'm just eye-balling it based on my friend's headlight alignment on the same wall in a garage.
To Crazy headlight alignment question
