Tire Sensor Needed?
Old Feb 10, 2004 | 02:12 PM
cthoreen's Avatar
cthoreen
Default Tire Sensor Needed?
Just bought some drag radials and a spare pair of wheels. Do you have to have sensors? If so then can I easily switch back and forth between my regular wheels and the drag setup?
Old Feb 10, 2004 | 04:16 PM
texasredc8's Avatar
texasredc8
Default Re: Tire Sensor Needed? (cthoreen)
You'll get a warning on the DIC that you can simply "reset" away, if you mount your tires without sensors in them.
There is really no choice, as only 4x sensors can be programmed at once, and you would have to reprogram your TPM system each time you changed wheels. That would be a PITA.
Old Feb 10, 2004 | 06:40 PM
cthoreen's Avatar
cthoreen
Default Re: Tire Sensor Needed? (TexasRedZ06)
Yes it would be a PITA. :) Mounting them w/o sensors sounds great. So all I have to do is reset after the DIC tells me there is a problem and them I can look at other things after that?
Old Feb 10, 2004 | 06:45 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Yes.
And if you are only bolting those wheels (w/o the sensors) on when you go to the track, it's very possible you won't even see a DIC error msg for a while.
:cheers:
To Tire Sensor Needed?
