Changed some things and codes came up
Old Feb 10, 2004 | 10:35 PM
PaC5_CHICK's Avatar
PaC5_CHICK
Default Changed some things and codes came up
just installed dual ram intake on my 97 and now the check engine light keeps coming on . When we pulled the codes p0171 & p0174 - fuel trim stystem lean bank 1&2 came up what do I need to fix this problem and will it hurt the engine running it this way???
Old Feb 10, 2004 | 10:52 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Changed some things and codes came up (PaC5_CHICK)
Sounds like you have an air leak somewhere. double check all you're couplings and your wiring that you unplugged to instal it also. make sure everything is together good and tight.
Also, I wouldn't drive it like that. You probably have un-metered air getting in after the MAF Sensor, which would also be un-filtered air...that wouldn't be good
[Modified by Flyin'Brian, 9:58 PM 2/10/2004]
Old Feb 10, 2004 | 11:37 PM
PaC5_CHICK's Avatar
PaC5_CHICK
Default Re: Changed some things and codes came up (Flyin'Brian)
the copler behind the mass air flow sensor was loose tightened it when I brought the codes up first time there was a HC after it (history and current) after reconnecting the copler the codes read p0171 H no C so cleared the codes and light went off and stayed off now for 10 mintues so I will check it again in morning TY for your help may need more tommorow
Old Feb 11, 2004 | 03:47 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I dont think the codes should comeup again. Looks like the leak was your problem :) Goodluck.
Old Feb 11, 2004 | 09:40 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
When changing airboxes the check engine light comes on once you start it up. You need to cycle the car (start it, drive it & shut if off) a few times and it will go away. If it doesnt, then it is time to start looking for problems.
VR :cheers:
Old Feb 11, 2004 | 07:27 PM
PaC5_CHICK's Avatar
PaC5_CHICK
Default Re: Changed some things and codes came up (vetterdstr)
Thanks that seemed to have worked no more light Im gonna be installing the 160 stat tomorrow any tips?
Old Feb 11, 2004 | 08:56 PM
vetterdstr's Avatar
vetterdstr
actually, the 160 thermo is not for a stock car... for best performance leave in the stock thermo. For High temp areas or S/C applications the 160 is suited best. :yesnod:
VR :cheers:
Old Feb 11, 2004 | 09:13 PM
PaC5_CHICK's Avatar
PaC5_CHICK
when we raced it at gainesville it was getting hot and have changed a few things on it already plan on getting heads and cams and new rear and power program as well when we ran it with the bra on was reaching temps of 240 When I talked to hypertech they said I sould run the 160?
To Changed some things and codes came up
