ZO6 exhaust performance gain?
you will see slight gains from the cat back (5 hp maybe) and it is a deeper throatier sound
and they look better too :)
hope that helps
gutting your C5 pre-cats
[Modified by Mike Mercury, 10:53 AM 2/11/2004]
AND, the titanium is truly lifetime, unlike stainless steel which can rust, I think the guys selling the ZO6 exhausts are going to regret it down the line.
I havent dyno'd, but the exhaust makes so little of a difference in performance, Ive seen it estimated as about a 5 to 8 HP gain MAX for the entire ZO6 system swap, and that was with intake mods, K&N, air bridge, MAF, etc.
Bottom line, it makes the car sound meaner, especially at full throttle and higher RPMs, but it sounds tame if your not flogging the pedal, and its all GM parts, for less than aftermarket, if you watch the forums and ebay.
Congratulations, and welcome to the C5 world.
hope that helps
The weight savings is around 17 pounds.
