Spec III - Post Install/Break In Questions
Old Feb 11, 2004 | 09:16 AM
SmoothFRC's Avatar
SmoothFRC
Default Spec III - Post Install/Break In Questions
I picked my car up yesturday and this thing shudders like a son of a bitch....
I hear the term chatters alot - but my car is shuddering when i try an launch the car.
I called spec and they said it is "normal", but i was not sure the proper procedures for breakin - should i try to shudder the car to assist with breakin or should i try and reduce the shudder as much as possible (Lauch off idle almost) and just deal for a while?
Also - The clutch Grab's really HIGH - is this normal?... I did replace the slave with the 02+
1 more thing - I drive alot of Highway miles.... what is the best way for me to expedite the break in process?
[Modified by SmoothFRC, 8:48 AM 2/11/2004]
Old Feb 11, 2004 | 09:21 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Spec III - Post Install/Break In Questions (SmoothFRC)
clutch grabbing high is normal. It will lower as time goes on. Did you install a alum flywheel? If so, break in will be in the 500-700 mile range. Steel flywheels break in a little faster 300-500 miles.
Old Feb 11, 2004 | 09:22 AM
Mike TexaSS's Avatar
Mike TexaSS
Yup thats the SPEC for ya!
You need about 500 miles of driving and then 8-9 WOT blasts down the 1/4 mile. Get the clutch as hot as you can get it. After that it should be fine.
Mine chattered like a SOB until i replaced my 99 Slave and master with 04 parts. But that was after my breakin.
Old Feb 11, 2004 | 09:34 AM
SmoothFRC's Avatar
SmoothFRC
Default Re: Spec III - Post Install/Break In Questions (Mike TexaSS)
what's the difference between chattering and shuddering...?
Old Feb 11, 2004 | 10:27 AM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
My Spec 2 sometimes squeals (sounds like a seal) upon engagement in first gear when its cold (alum flywheel) - has anyone else had this problem? It is about 800 miles old....
I called Spec and they said its normal....
Old Feb 11, 2004 | 12:03 PM
dahoof's Avatar
dahoof
Default Re: Spec III - Post Install/Break In Questions (OliverM5)
I have not heard of a clutch squealing. But It took at least 1000 miles for mine to quit chattering. Good Luck!! :cheers:
Old Feb 11, 2004 | 02:00 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
I do not know what you are meaning when you say launch. Is that launch as in at 2-3000 rpms or just taking off from a stand still.
I had my SpecIII installed in the middle of December and I still am babying the thing, no launches at all, just smooth as possible in/out.
I have the aluminum flywheel and have had to provide a little more throttle to get going good but not so much as to actually launch as I would at the track.
I was told that the SPEC III will only be as good as the break in.
:cheers:
Old Feb 11, 2004 | 03:57 PM
SmoothFRC's Avatar
SmoothFRC
Default Re: Spec III - Post Install/Break In Questions (AnteVenom)
I mean from take off... It seems that i almost have to "take off" off idle to avoid the shuddering/chattering and i was just curious what others were/have experienced as well.
To Spec III - Post Install/Break In Questions
