I think Bank 2 sensor 1 is the preferred O2 to monitor because #7 is supposed to show the first signs of leaning out. Please no "monitoring narrow band O2 sensors is a waste of time" comments.
I was looking through my Helms last night looking at the pinouts on the PCM for which wire to tap into for the Bank 2 Sensor 1 O2 sensor for an A/F gague. There are two wires listed. One says HO2 "Bank 2 Sensor 1 High" and the other says "...Low". What is the difference and which do you tap into to read the O2 voltage?
Because I don't feel like parting with the hundreds of dollars for EFI Live, AutoTap, laptop, Predator, Etc. when all I need to do is hook up a multimeter.
Granted I won't have LTFT, KR or other data but I really just want to see if -2 is enough on my MAFT. Also I am thinking seriously about a dry N2O kit and I want to make sure I'm not leaning out the first time I spray it.
You need to connect the two leads of the voltmeter to both the low and high signals. Be sure to use a high input impedance meter (DVM). Don't use something like one of the old Simpson meters since the loading may affect the reading.
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Re: A/F Gauge Hookup: Which Wire (5 Liter Eater)
You will not learn anything about your MAFT setting because the PCM will always maintain stoich during closed loop operation based on O2 sensor feedback and fuel trims. So I can tell you right now that the gauge is gonna indicate 14.7:1 while cruising around, unless you have a check engine light.
The only time you will fall out of stoich is if your trims are maxxed out and you would get a check engine light in that situation. This gauge will also be fairly useless at WOT because the stock sensor is not really designed for that A/F range, you are not logging data for analysis, and you will not be able to watch the gauge and determine what is going on without killing someone. No offense intended, but this sounds like an exercise in futility.
Thanks sunvet.
rbartick, I'm fully aware that the A/F gauge will flip back and forth during closed loop operation. What I'm trying to find out is my WOT O2 voltage to give me a good idea of my A/F ratio. Obviously if this reading is too rich (>~.875 mv) I won't know if it's because of positive LTFT's or what.
I knew it would be impossible to bring this up without some narrow band O2 sensor bashing. :rolleyes:
:iagree: Since it was already brought up I will just agree with it
sorry, but you did expect it :lol:
You call it bashing? He gave you sound advice, especially if you are going to spray. My 02's read about .860 at 13.1 AFR. I've seen them over .900 at 13.1.
Hope it works out.
You gotta be kidding me with this joke of a reply. I guess this is what you get for trying to help someone avoid unnecessary work. I didn't realize that stating the facts was considered to be bashing.
That DVM is going to be all over the place when you try to do a WOT reading and the results from one run to the next will be unpredictable even if you change nothing. Have you ever seen the readings that come from the stock O2 sensors at WOT? In addition, without data logging your readout will be absolutely worthless.
How can I fly to the moon in my C5? Please do not reply by saying that attempting to fly to the moon in my C5 is a waste of time.
Here are some stock O2 reading taken from a 1/4 mile blast:
Click image for a larger view
I usually get different readings on every pass even if PCM learning is long completed and I do not change a thing. I should add that monitoring knock is just as important as monitoring the A/F ratio. Knock retard can easily occur if your mixture is off and that will really kill power.
OK, granted there is ~.025 variance but from that I would say you're running rich seeing as how you are in the .900 mv's. What was your other run like? Were the O2's in the high 800's, low 900's again or totally different? A long 4th gear pull should show even less variance.
Granted you probably want to run rich seeing as how it looks like you're blown, by which I mean supercharged, if you're trapping @ 124.
Or maybe you're spraying seeing as how the IAT drops, I've never seen a spraying autotap but I would think the IAT would go real low. That and the timing doesn't look as high as it should which points me back to FI. Hey all this data is neat, you must have a lot of multimeters. :lolg: Just kidding, I couldn't resist. Meant to be harmless. :cheers:
The car is stock. I just kept into the gas for a few seconds after I passed the lights. The run can be seen here: http://www.rbartick.com/race_z06.htm
The VR airbox I have is responsible for the drop in IATs. You can also see my MAP climbing a bit at speed. In that run was car was running pretty good but I am not sure what my actual A/F was. I can upload an even leaner tune and the stock O2 sensors may still report the same thing as this run. If I go leaner I start to knock even though I run the stock timing.
Also on my car the A/F starts lean, gets rich around the TQ peak, and then leans out again up towards the redline. This is not indicated at all by the stock O2 sensors. Over the summer I spent some time tuning my car on the road with the stock O2 sensors. I went to the dyno with what I thought was a good tune and I found out that my A/F curve looked like a Motor-Cross track with a huge lean dip right before the Tq peak. This was not indicated at all with the stock O2 sensors.
Bottom line, I cannot depend on the stock O2 sensors at WOT.
Point taken. Perhaps the stock O2's are not good for telling me if I should go another 2% lean on my MAFT.
But they will be good in telling me if something is wrong with my future nitrous setup. I'm going to be trying different ways to plumb a dry nitrous kit into my Vortex and am afraid that I may freeze the MAF since it's so close to the filter. Dyno Tune has a module that will shut off the N2O if it detects an overly lean condition http://www.speedshop.org/store/scrip...p?idproduct=67 and I will still need to know the wires to tap into for this or a multimeter.
Now I know the wires and have a different perception of narrow band O2 tuning. So it's a win-win. Rbattick, you work on getting those LTFT's negative. :p:
