Shifter tension
Mike
I installed mine last night, and it feels fantastic (see my thread further down the page). No issues whatsoever. It's still a bit too stiff for my tastest, but folks say it loosens up for the next few weeks of driving, so I'll reexamine my thoughts then.
-J
-J
Some up and down movement of the stick is disireable to prevent binding in the socket and the lingage, but it should not be just flopping around in there.
This is not a problem on the OEM shifter because the "Pivot" is all rubber and it completly "captures" the stick. It also allows some up and down movement
AS was reported here you have the option to use light springs but the majority of the side tension is in the transmission linkage itself and theres not much the average guy can do about that!
I myself reduced the effect of the Hurst springs as much as possible with the light springs (one light weight spring per side) and only turned the retaining plugs in a couple threads. I used lock tite on the threads to prevent then from coming out and falling into the shifter.
It's tight, no doubt about that, but not as tight as it was. I expect it will loosen up as I go along and not be so noticable after I change the oil this spring
Even with the lightests spings and the caps only in a few threads (Hurst) it's the stiffest shifter I have ever encountered. Other owners have reported they breakin with time mine only has 1500 mi. on it. I'm sure any short shifter will be stiffer just because the leverage you give up with the shorter handle. Some people have also reported vibration issues with short shifters because there is no rubber in the handle like the factory one. This problem seems to vary in degree depending on the shift **** used. Noise is also a factor although there are several solutions that have been posted on the forums most work well. I used the 2in rubber plumbling cap one and it's pretty quit again. Hope this helps, Bob
[Modified by bbvett, 7:10 PM 2/13/2004]
Mike
