So if I were to go with the catless version (since I could then theoretically afford a cam too :D ) could it be tuned so that I wouldnt have a problem with smelling gas from the rear? Also, if at some later point, I need to install cats, would I be able to add those to the set up without too much trouble? Thanks for the help.
If you remove the cats it is going to stink no matter what
I disagree, I have had mine for several months now without any tuning and I have do not have any "stink" issues. I plan on having some tuning done this spring to squeeze a bit more HP out of it now that the LT's are on.
I have the LG Pro headers and an LG Cam Only package without cats. With tuning there is a slight odor, but not that bad. I don't spent much time with the car idling in my garage with the door closed, so I don't have a problem. :D
