C5R heads, where-how much etc
Old Feb 13, 2004 | 05:12 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Default C5R heads, where-how much etc
Do you order c5r heads from GM, from Katech? how expensive are they and is this bare head--I am thinking that to save the value of the the head it would be better to change pistons than try shrouding etc to get these to a streetable CR of say 11.25 CR--there is no doubt they outflow anything available and I'm sure they will outflow anything in the works like the AFR's--they are obviously either hard to get or very expensive or completely impractical or more people would be applying them to their cars---
Old Feb 13, 2004 | 05:18 PM
kumar75150's Avatar
kumar75150
Default Re: C5R heads, where-how much etc (NEPTUNEBILL)
I know you need a custom intake manifold to accomodate the heads.
Besides the cost of the heads, the extra 2 grand for the manifold is another turnoff.
Old Feb 13, 2004 | 05:21 PM
kumar75150's Avatar
kumar75150
Default Re: C5R heads, where-how much etc (kumar75150)
I think you also need different rockers, special valves, pushrods, and maybe custom fuel rails.
I think a bare set of C5R heads is around 4 grand. Just a guess.
Ported C5R heads can flow close to 400cfm.
[Modified by kumar75150, 4:24 PM 2/13/2004]
Old Feb 13, 2004 | 05:33 PM
NEPTUNEBILL
:lol: :lol: :lol: Sorry I asked--I think a 100K+ is enough to put into this car I can see another 20K to get these heads up and running but boy would 400cfm be sweet--than another 5K+ to get an intake and TB that would feed it--I should have gotten an LPE 427TT with boost controller and been done with it--
Old Feb 13, 2004 | 06:09 PM
kromberg's Avatar
kromberg
Last time I checked, the bare C5R head was about $1200ish. The head is layed out in that it requires at least a 4.10" bore cylinder. Beside the point mentioned about the custom intake, the non full race version uses 38cc chambers so a serious dish piston( -24cc ) would need to be used.
Keith
Old Feb 13, 2004 | 07:11 PM
blktie8's Avatar
blktie8
special headers also
Old Feb 13, 2004 | 07:37 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
You and me both... :yesnod:
VR :cheers:
Old Feb 14, 2004 | 12:56 AM
NEPTUNEBILL
Default Re: C5R heads, where-how much etc (kromberg)
Keith--I've got the 4.1 bore--I assume thats 1200+- each, do you know if the hardware I have on these new heads would work on them, valves, springs, roller rockers etc--I would think a sheetmetal intake would feed them at a reasonable CR if we can find a TB that will draw enough air--I assume it would only be practical to go solid roller with them--
Hell I didn't think about headers too--I wish I had done this to start with I have too much in the current setup already--
Old Feb 14, 2004 | 02:44 AM
Sir Sel's Avatar
Sir Sel
Default Re: C5R heads, where-how much etc (vetterdstr)
VR :cheers:
Add me to the list. :iagree:
Old Feb 14, 2004 | 06:20 AM
marco383's Avatar
marco383
Default Re: C5R heads, where-how much etc (Sir Sel)
Bill:
I'd go back to a blower before I got involved with all that C5R mess. A 427 (or your 436) with 9:1 C.R., an appropriate blower cam, and a T-Trim Vortech at 11-12 psi should be good for at least 700 RWHP, and would probably be a cheaper conversion than going C5R. It would require more sophisticated engine management and an upgraded fuel system, but I did all that on my dear, departed Camaro and the results merit the effort.
We're never satisfied are we?
Old Feb 15, 2004 | 10:20 AM
till's Avatar
till
Kinsler has nice looking intake manifolds. Too pricey for me though.:cry
http://www.kinsler.com/i_manifolds.htm
Till
[Modified by till, 9:21 AM 2/15/2004]
Old Feb 15, 2004 | 10:58 AM
marco383's Avatar
marco383
Default Re: C5R heads, where-how much etc (till)
You'd also need a complicated, mechanical throttle linkage assembly, custom fabricated air intake, etc., etc.
Life is too short to go out of one's way to look for aggravation.
Old Feb 15, 2004 | 11:20 AM
NEPTUNEBILL
Default Re: C5R heads, where-how much etc (marco383)
I'm with you Mark--screw it I would just like what I have to reach its potential and it will be more than adequate--I would settle for a decent idle right now--drawing 5 inches of vacuum at WOT--I need the FAST 90 setup to work and that will be enough for gods sake, I really just want a good fast powerful and fun street car--
Old Feb 15, 2004 | 02:01 PM
marco383's Avatar
marco383
Bill:
Maybe we'll get there at the same time. See you at the shootout.
Old Feb 15, 2004 | 06:17 PM
NEPTUNEBILL
I hope so and yes you will see me next weekend--
To C5R heads, where-how much etc
