Low beam replacement
Old Feb 13, 2004 | 08:21 PM
powerslide91's Avatar
powerslide91
Default Low beam replacement
Hey all,
My mom has a '99 C5 which has burned out one of the low beams. Can someone explain to me what is involved with changing this out? She is in CA and I'm in TX, and I hate the thought of having to tell her to go to a dealer / shop to get something like this fixed. I'm hoping it is easy enough I can walk her through it on the phone as she is not a 'car guy', so to speak.
Thanks!
Jeff
Old Feb 13, 2004 | 08:23 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Low beam replacement (powerslide91)
Withe headlight in up position remove the 3 or 4 bezel screws and bezel...reach twist and pull...insert new bulb
Old Feb 13, 2004 | 08:28 PM
kedvesh's Avatar
kedvesh
Default Re: Low beam replacement (pewter99)
:iagree:
If your mom is not a Techie, then have her get some trustworthy teen to do it and reward him w/ a couple of movie tix or something. :grouphug:
Of course, you could also do a test run on a local 'Vette (at least look at the headlight assy) so you can advise her or whomever what to be on the lookout for. :yesnod:
[Modified by kedvesh, 8:32 PM 2/13/2004]
Old Feb 13, 2004 | 09:16 PM
powerslide91
Default Re: Low beam replacement (kedvesh)
Cool, thanks for the info, sounds like cake.
Good idea on the 'test drive' :yesnod: Why didn't I think of that??
To Low beam replacement
