There was a great article in Grassroots Motorports magazine talking about brake changes and bias. You will upset the bias with larger calipers, but may be able to correct for this through other means. You may not notice the difference until you really hit them hard. The last thing you want is to find out there is a problem when you need them.
I found from personal experience that the car stopped flat instead of the typical nose dive, that's from 1st hand expereince, and I used no bias spring or proportioning valve.
From: Buy USA products! Check the label! Employ Americans
Re: Front calipers on rear? (Slammed Vette)
You can do it but will need a bigger master cylinder, lose the Ebrake as said above and probably need a bias valve. Won't really help unless you put a big brake kit on the front. Front left to right rear when mounting. I haven't done it yet but will soon.
