question on a RESISTOR for f45 delete
Old Feb 15, 2004 | 10:15 PM
MUKAK's Avatar
MUKAK
Default question on a RESISTOR for f45 delete
i installed 04 z06 shocks in place of my f45 now i have that reduced mode on my DIC i bought some resistors but i wasnt sure wut wattage so i got some 5watt 15 ohm resistors
did i get the right ones ???? :confused:
some1 please advise b4 i waste 1 hour of my time putting them in
thanks :cheers:
Old Feb 15, 2004 | 10:38 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: question on a RESISTOR for f45 delete (MUKAKsC5)
Take it to the dealership and have them turn off the F45 option...
VR :cheers:
Old Feb 16, 2004 | 12:22 AM
MUKAK's Avatar
MUKAK
Default Re: question on a RESISTOR for f45 delete (vetterdstr)
I DONT WANT TO PAY THE dealer TO TURN IT OFF I WANT TO DO THE resistor trick
Old Feb 16, 2004 | 01:04 AM
vetterdstr's Avatar
vetterdstr
Here is the trade off, install the resistors and if you get it right, everytime you start your car you will have to clear the codes that the shocks will set. Or you can buy the LAPD units for $200 and not reset codes... or you can get someone with a Tech II (Friend, Dealer) to turn off the feature on your car with NO CODES TO RESET EACH TIME YOU GET INTO YOUR CAR, and no $200 plugin's
Do whatever is best for you, it is your car.
VR :cheers:
[Modified by vetterdstr, 10:15 PM 2/15/2004]
Old Feb 16, 2004 | 01:30 AM
MUKAK's Avatar
MUKAK
THANKS vettesder I DIDNT KNOW THAT IF I DO THE RESISTOR TRICK I STILL HAVE TO CLEAR THE dic EVERYTIME ILL JUST TURN IT OFF AT THE DEALER
THANKS
Old Feb 16, 2004 | 01:38 AM
corvette184's Avatar
corvette184
i have found the sensors for 160.00.......here is a link http://www.ls1speed.com/catagory.cfm...ory=suspension
Old Feb 16, 2004 | 02:45 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
I brought the directions on how to do it with a tech2 to my friendly dealer with a 20 and had him disable the F45. It worked great! Do a search on the forum for it. Sorry I don't have it handy.
JB
To question on a RESISTOR for f45 delete
