Clutch Replacement - Labor Cost?
Old Feb 16, 2004 | 01:17 PM
Arthur6's Avatar
Arthur6
Default Clutch Replacement - Labor Cost?
I need a cultch in my 99
How much should I expect for labor?
I see Z06 clutches all over the place for $350 (parts)
[Modified by Arthur6, 10:17 AM 2/16/2004]
[Modified by Arthur6, 10:19 AM 2/16/2004]
Old Feb 16, 2004 | 01:19 PM
Arthur6's Avatar
Arthur6
Default Re: Clutch Replacement - Labor Cost? (Arthur6)
t
Old Feb 16, 2004 | 01:47 PM
GettReal's Avatar
GettReal
you can probably anticipate about 6-9 hours of labor and depending on your shop rate that can really range. 400 for parts on a Z06 clutch or Stage I is about right.
Old Feb 16, 2004 | 03:34 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Labor is 7 hours, I know guys who have done it in five. but the dealer will charge 7.... if you replace the clutch.. you should upgrade the slave and ,master too... they are 100 dollars each, for z06 slave and master..
Old Feb 16, 2004 | 03:41 PM
gmblack3's Avatar
gmblack3
Default Re: Clutch Replacement - Labor Cost? (Evil-Twin)
500-700
Old Feb 16, 2004 | 04:06 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
I have seen anywhere from 700-1400 dollars. Call around but make sure you go somewhere that you can trust. Kaley
To Clutch Replacement - Labor Cost?
