LS6 intake vs FAST intake....
Old Feb 20, 2004 | 02:39 PM
Izover4u's Avatar
Izover4u
Default LS6 intake vs FAST intake....
Wondering how these two compare to each other?
Thanks guys :cheers:
Old Feb 21, 2004 | 12:05 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Default Re: LS6 intake vs FAST intake.... (Izover4u)
We just got are first fast intake in the other day. I saw the intake at the PRI show in Indy and like it. They made small but good changes, we have cut into LS6 intakes and found horse power. The intake comes in a nice box with nice instructions and is well put together. We are in middle of putting the intake on a 427 cub motor, it should make horse power with the 90 mm opening. I'll keep you posted.
Randy
Old Feb 21, 2004 | 09:03 PM
Izover4u's Avatar
Izover4u
Default Re: LS6 intake vs FAST intake.... (Randy@DRM)
:thumbs:
Old Feb 21, 2004 | 09:16 PM
EFI-1's Avatar
EFI-1
:lurk:
Old Feb 22, 2004 | 03:20 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Thanks DRM" fo your info and welcome ! :cheers:
Old Feb 22, 2004 | 09:45 AM
Gene@FredBeans's Avatar
Gene@FredBeans
I think at this point it will be FAST vs LS2 intake... soon..
Gene
Old Feb 22, 2004 | 05:38 PM
Cobraeater's Avatar
Cobraeater
Default Re: LS6 intake vs FAST intake.... (Gene@FredBeans)
Gene, I thought the ls2 intake won't be out till July or August? :confused:
Old Feb 23, 2004 | 01:33 AM
Izover4u's Avatar
Izover4u
Gene
:confused: :confused:
Im little confused.. when u say LS2 you are talking about the C6 intake correct? Does this mean that the C6 "LS2" intake will work on our C5s? :confused:
Old Feb 23, 2004 | 10:09 AM
Gene@FredBeans
Even if they won't be out for a little while they'll still be a comparison point.
I'm told by the GM Engineers that most, if not all, engine parts will bolt up and work.
Gene
Old Feb 23, 2004 | 10:43 AM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Randy
This is what I am waiting for.......PLEASE keep us posted!!!!!
Old Feb 23, 2004 | 11:45 AM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In IV Veteran
Gene
If true, this is good news...maybe an affordable 90mm Intake and TB :hurray:
Old Feb 23, 2004 | 01:53 PM
Carsnob's Avatar
Carsnob
Here's a link with some good disscussion about the new LS2. Scroll about 1/4 way down to Rick76's post as it has the most info and not just hearsay.
http://www.ls2.com/forums/showthread...8&threadid=567
Old Feb 23, 2004 | 06:09 PM
triumphman's Avatar
triumphman
2nd Gear
what throttle body are you using?
Old Feb 28, 2004 | 12:25 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Default Re: LS6 intake vs FAST intake.... (Buckmaster)
Sorry it took awhile to post our results. Anyways now for the real test we made base line runs with the LS6 intake and got it tuned. Then Mike in the shop put on the fast intake with the 90mm hole and we pick up 22 horse and 22 foot pounds of tourqe. The calibration went alittle off with the fast intake. So back to work.
Randy :party:
Old Feb 28, 2004 | 12:53 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Randy what TB did you use for the test--very impressive results--I am tuning the setup in on my 436 this, just got a 90mm TB and looking for any comparison to test my tuning with--thanks Bill
Old Feb 28, 2004 | 03:27 PM
SideStep's Avatar
SideStep
I cannot speak for the big ci motors but for stock displacement gains looks to be 6-10RWHP on a back to back compassion with the LS6 intake (stock and 78mm TB). There are tons of post over at the LS1tech forum on it... Considering the price ($750-800) I would say this is a mod for the big motors....
:cheers:
[Modified by SideStep, 3:29 PM 2/28/2004]
Old Feb 28, 2004 | 07:14 PM
NEPTUNEBILL
Default Re: LS6 intake vs FAST intake.... (SideStep)
You will find a bigger gain on the strokers because of what they are lacking not what the intake is adding--the real test is probably on the smaller ci cars it shows what power the unit really adds--my stroker is drawing 5 inches of vacuum at WOT--just eliminating this would give me considerable gains--I still wonder what TB they used on the test in this post since the 90mm tb's are just available I am wondering if they had access to one in time for this test--
Old Feb 28, 2004 | 07:57 PM
2KREDVert's Avatar
2KREDVert
Default Re: LS6 intake vs FAST intake.... (NEPTUNEBILL)
Who has the best price on the 78mm throttle body Fast Manifold? I have seen a wide array of prices out there. I am a firm believer in doing the cam swap at the same time. Maybe a Comp #54-412-11 I have a stock LS1. Phil Swanson
To LS6 intake vs FAST intake....
