Tire sensors
Old Feb 21, 2004 | 10:21 PM
lar66BB's Avatar
lar66BB
Default Tire sensors
Can you turn off the sensors in the CPU, or what happens if you just
take them out and go to none run flats, will you get any codes.
:cheers:
Old Feb 21, 2004 | 10:29 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Tire sensors (lar66BB)
On a 2001 or later car, the TPS system can be turned off with a Tech-2 programmer.
On 97-00 cars I don't believe there is a permanent way to disable.
If you remove the sensors, you will probably get a "serice tire mon. sys." message on the DIC every time you start the car. Just hit reset and go on as normal, it doesn't limit speed, cut power or affect anything else.
:cheers:
Old Feb 22, 2004 | 12:45 AM
dbarbosa's Avatar
dbarbosa
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Tire sensors (Y2Kvert4me)
:iagree:
I just bought some sensors and am going to have my cpu turned on. :D :D
D.
To Tire sensors
