HELLO,I AM A CORVETTE(2001 COUPE) OWNER FROM TURKEY!I MADE SEVERAL MODIFICATIONS TO MY CORVETTE AND I WANT TO CHANGE THE SHOCKS AND THE SWAR BAR KIT!I WANT TO BUY BILSTEIN SHOCK AND HOTCHKIS SWAY BAR KIT!BUT THE QUESTION I WANT TO ASK YOU IS THAT IF I INSTALL THE NEW BILSTEIN AND HOTCHKIS KIT,WILL THEY EFFECT THE ACTIVE HANDLING SYSTEM? DO I NEED TO CHANGE OR ADJUST THE ACTIVE HANDLING SYSTEM AND CAN I USE COMPETITION MODE(ACTIVE HANDLING'S OPTION) WITH MY NEW SHOCKS AND SWAY BAR KIT?
well,thanx for the suggestion really,by the way i am not yelling,just to attract attention thanx!
Using all CAPS is considered to be yelling on the PC keyboard, FYI. You can make use of the Bold, Iltalics, Underline, or smilie options for emphasis in your text.
Won't impact the Active Handling at all. The changes should help the handilng of the car quite a bit. I'd recommend the T-1 bars if you are ever thinking about taking the car to the track.
