car running hot need help
Old Feb 22, 2004 | 02:56 PM
hot4u's Avatar
hot4u
Default car running hot need help
On the way to work this morning dic on my 98 coupe said coolant was reading hot around 255. I made it to work checked hoses, fans, and coolant all working. car runs fine no unusual noises. Just now stared it up again temp went up to 250be fore i shut it down. just would like an idea of what it might be before I take it to the dealer , out of warranty :confused:
Old Feb 22, 2004 | 03:44 PM
addicted to race's Avatar
addicted to race
Default Re: car running hot need help (hot4u)
don't wait!!!go to the service as soon as possible!on the other hand use thermostat in order not to run into engine cooling problems!
Old Feb 22, 2004 | 04:14 PM
dpd's Avatar
dpd
do you have heat?when the car is hot,is the lower radiator cold?if so,the thermostat is bad.also make sure you have no leaves,bags,etc,stuck up in the radiator air intake.
Old Feb 22, 2004 | 04:46 PM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
Default Re: car running hot need help (dpd)
check these things before you go pay for service
1. Engine coolant is full
2. Make sure that no debree (sp) got picked up by the car and is blocking the air from flowing through the radiator. Platic bags are notorious for that.
3. If you have checked the other two, go ahead and change the thermostat, it is inexpensive, especially compared to a dealership service charge
None of this works, you can take it to the shop and let them find the problem. :cheers:
Old Feb 22, 2004 | 04:52 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: car running hot need help (Mr. Big)
:iagree:
This may be an easy fix :cheers:
To car running hot need help
