Air bridge Question??
Old Feb 22, 2004 | 03:18 PM
88_vette's Avatar
88_vette
Default Air bridge Question??
Does anyone know/find out, at what angle the bend in the air bridge on the C5 is at? thanks
Old Feb 22, 2004 | 05:34 PM
88_vette's Avatar
88_vette
Default Re: Air bridge Question?? (88_vette)
OK Does anyone have a guess at the angle? I don't have one so it's kinda making it hard to get the angle, or even guess based off pics, but from what I"ve seen it appears to be around a 45* bend :confused:
Old Feb 22, 2004 | 08:09 PM
David Plum's Avatar
David Plum
WHY
Old Feb 22, 2004 | 11:37 PM
88_vette's Avatar
88_vette
Default Re: Air bridge Question?? (David Plum)
Because I'm building something (way to much to go into, and you most likely wouldn't care if I did) and I think the air bridge from a C5 would work well if that angle, or degrees is enough. So, do you know what it is David?
Old Feb 22, 2004 | 11:53 PM
ChevyChad's Avatar
ChevyChad
Id say its more along the lines of 30 or 35 deg. 45 is definately too much from what I would say. Hope this helps any. But enlighten us, just give us a brief description of what you are congering up :)
[Modified by ChevyChadZ28, 10:54 PM 2/22/2004]
Old Feb 23, 2004 | 12:03 AM
88_vette's Avatar
88_vette
Default Re: Air bridge Question?? (ChevyChadZ28)
I can't say much now. I'm affraid someone on here may get the idea and run with it. It's happen once already with one of my ideas a few years back.
Thank you greatly for the info though it helps out a great deal.
I'll IM the idea to you.
To Air bridge Question??
