stock shifter with Hurst short throw??
Old Feb 23, 2004 | 09:54 PM
henchmen3's Avatar
henchmen3
Default stock shifter with Hurst short throw??
Any problems using a stock c5 shifter **** with a hurst short thorw shifter?
thanks
Old Feb 23, 2004 | 10:22 PM
BlackZ06's Avatar
BlackZ06
Default Re: stock shifter with Hurst short throw?? (henchmen3)
No problem at all. That is the way my car is set up - Hurst shifter and stock ****. Until you actually shift gears, you can't tell it has the Hurst because it looks totally stock.
Steve
Old Feb 23, 2004 | 11:48 PM
dfwroadkill's Avatar
dfwroadkill
St. Jude Donor '07-'09
The only problem I know of is that the Hurst tends to rattle. If you install a heavier aftermarket **** it ends to reduce or eliminate the rattle. You can search the threads and see this all over the place.
But simply, the **** fits and you can use it.
Old Feb 23, 2004 | 11:55 PM
Sorny's Avatar
Sorny
The only problem I had was getting that fscking T-nut off so I could pull the **** off. :mad
I'm running the stock **** on my Hurst and love it. I've not found a more comfortable **** to use, and I like the feel of the stock ****. The Hurst should have come stock, IMHO, just like the FRC partition should have been stock.
Sorny
Old Feb 24, 2004 | 12:13 AM
syndicate's Avatar
syndicate
Default Re: stock shifter with Hurst short throw?? (Sorny)
None, the stick has exact same threads.
Old Feb 24, 2004 | 09:27 AM
henchmen3's Avatar
henchmen3
Default Re: stock shifter with Hurst short throw?? (syndicate)
thanks to everyone, just didnt want to buy a new **** unles I had too.
Old Feb 24, 2004 | 11:11 AM
BLU-JACKET's Avatar
BLU-JACKET
Default Re: stock shifter with Hurst short throw?? (dfwroadkill)
:iagree: If you do decide to change, the $36.00 MGW **** works great.
Old Feb 24, 2004 | 03:00 PM
henchmen3's Avatar
henchmen3
Default Re: stock shifter with Hurst short throw?? (BLU-JACKET)
what is the MGW ****? who has it?
Old Feb 24, 2004 | 04:54 PM
BlackZ06's Avatar
BlackZ06
I found that my rattle was caused by not getting the key back into the shifter **** properly. It worked loose and the **** was rattling on the end of the lever. Once I got it in properly, my Hurst has performed flawlessly.
Steve
Old Feb 24, 2004 | 07:00 PM
Lancer033's Avatar
Lancer033
:iagree: I put up with that for a while, then finally broke down and got an aftermarket ****. It's actually not that bad and i got the aftermarkt **** more for the look than the rattle. There have been some fixes posted for this problem, something to do with wrapping the shifter with something before you reinstall the ****, but i don't remember exactly what.
To stock shifter with Hurst short throw??
