ASP underdrive pulley ?
I recently bought one and when it arrived I noticed the pulley had quite a bit of black/dirty grease on the outer surfaces and down into the pulley grooves as well. The grease resembles that which might be on the pulley if it had been used previously. Is the outer pulley a "take off" from another model car or are these brand new manufactured units?
And there was a large chunk of the rubber missing from the rubber that separates the inner and outer hub on the front side of the pulley.
Is this typical quality for these units? And will the missing chunk of rubber cause any problems in the future. ie premature failure?
Just looking for some feedback on this.
Does this look normal?
[Modified by Z06ufgrad2002, 6:22 PM 2/24/2004]
